[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
Router rebooted. (30 second power disconnect)
Still doing the connecting disconnecting dance, with a constant scanning. It sees the network just fine but will not connect. The quick panel icon is lit up but there is no wifi icon in the notification bar.
This was reported by someone else about 2 pages above me but gave no detail and has not followed up.
My router is wide open with no security and SSID broadcasting is on. I've tried a re-adding the network to my phone manually with no luck.
I'm installing a wifi scanner app and I'll see if I can find an open network to try to attach to so isolate the problem. But nothing changed on my router or network.
Might be a a little while before I find one. I'm going to have to cruise the neighborhood to find one.
You could awlays try the eb01 kernel in the first post.
I just installed the EB16 voodoo kernel and still cant get voodoo to kick in. Not sure what is going on. I have wiped cache and dalvik but not data. Neither sc 2.8 or the kernel itself appears to be allowing the conversion to take place.
I'll give it a try and see how it goes.
I created a new open network on my router with a new name, so it wouldn't have anything to do with remembered settings and same problem.
That fixed it. Not sure why EB167 worked in 2.6 but every flash is an adventure.
Just for edumacational reasons I'll reflash EB16 just to see what happens.
Much thanks for all these great ROMs and for your assistance it getting my phone fully working again.
Update: Flashing the EB16 Kernel brought the problem back. There is nothing I need in EB16 so I'll stick with EB01.
Vids play perfect again, and can lock the screen so little fingers cant tamper. Thank you very much again Adrynalyne.
Has anyone noticed the soft key lights don't come on when the screen is powered up in SC 2.8?
Still true on 2.8
2.8v works like a champ for me. Softkeys work. Fast. No issues yet. - Thank you.
I am noticing that now too. If the phone is sleeping and you hit the power button and unlock the screen, the soft keys do not light up. Doing anything withe the screen does not get the soft keys to light up. The only thing that gets the soft keys to light up in pressing one of them.
Seeing the same softkey issue as Landshark posted. I hit the power key to turn the screen off. Hit the power key again to bring the screen back. The softkeys are off. I swipe to unlock and the softkeys are still off. Once I touch one of the softkeys, then they will come on. EB16/SC2.8nv
same here. Not a big deal to me. Just no lights on the softkeys when waking screen.
Sent from my SCH-I500 using Tapatalk
need to clean caches?
im running sc 2.6, do i need to perform any wipe of caches before/after flashing sc 2.8?
Yea mine is doing this anyone else was it part to save battery or what?
Not sure. The lights do come on for a split second whenever you press the power button (wake), unlock, press the power button (sleep).
Status
sukorenojaya
