[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
This is kind of like the blind leading the blind here, I think the patch is for a different kind of transition, different than stock, but hopefully someone else who knows the answer can hop in.
Adrynalyne said the patch was for pop up transitions, but I still don't know what that is. I downloaded the patch on my sd card and I'm just going to flash it through cwm and see what I notice is different.
Sorry everybody, I can't see any difference. So I still don't know what that patch does.
I flashed the patch in the same session with the 2.3 so I can't help much but I do remember them in 2.2 they are way cool. They seem to happen in a random pattern.
When I bring dialer up it comes in from the side, but I do remember it splashing up from the center.
In any case Adry has the patch meant for 2.3 so if you are missing these transitions, flash away.
So does the transitions patch basically just randomize where things pop up from when going from one to another? Say homescreen to dialer, homescreen to messaging, etc? Hence pop up transitions.
when you press the settings menu, it kinda bounces a little. things like that.
Reactions: Landshark
So basically, it doesn't do much
EDIT - Also Gunner, what qualifies as a brick?
it does neato little eye candy stuff. i like it. :p
lol. a brick is anytime you phone is unusable and requires some fixing to get working.
it is also something you build houses with.
sometimes if i almost get in a wreck or something scarry like that, its something i crap. ;)
soft brick- is Phone...!.....computer image you can recovery from this by flashing odin
hard brick- phone will not turn on at all,,, only way out of this is using a jig and i dont know if that even works, i pray i dont run into this situation but also it would be great to find out if the jig works
"Sorry, I'm lazy"..... im not sure what to say to that..... can some one help me out here? Adrynalyne just said he is lazy.....
Hey I just woke up from my nap and saw there's a 2.4 v but I can't download it? Where's the link? Does someone have it please give it to me thanks.
holy ****, adrynalyne...thank you very much. samsung should be throwing bags of money at you.
or el googlymoogly
Is it safe to assume that I can try to flash any boot animation? What is the worst that could happen?
OK, at least I will know when I officially brick so Gunner and Sheepy can be happy. Closest I have come is a force close loop of hell
Status
rido7788
