[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
Ok I am just having two problems with this. Email and words with friends don't work. Help please?
Sent from my SCH-I500 using Tapatalk
Is the battery full popup supposed to be disabled in 2.4? I am still seeing it. Is there a "switch" to enable this?
Thanks
Did you install a theme? If so the theme may have overridden the disable.
Yes. I wondered about that but I thought I read it would most likely not affect it. I need to check.
Has anyone had any issues with bluetooth voice dialing?
Did you flash the Nuance_froyo.zip? You will need this for voice dialing.
Reactions: OHFIRE
You can, or you can download Adrynalyne's latest build - superclean 2.4 which has the fix built in - and install it with clockwork
Thanks. I installed it but the long press still doesn't work. I guess I can live with a short press then hitting the microphone in google to finish the search unless you have any ideas.
What is the "Clean quickpanel by benbowden?"
Also, how do I use the screenshot app?
Found the answer to your first question in another thread started by Bendbowden. Quickpanel is those five icons at the top of your notification bar when you pull it down. He cleaned it up by taking the "mobile" out of mobile data and the "auto" out of auto rotation so everything fit better on the screen and wasn't so smashed together.
Thanks of this. I never even noticed this, but was wondering what it was myself.
You can flash the Touch of Blue theme like I did. It also has the longpress search fix and mine worked when I was running 2.4 with the theme.
Hmmm. My long press actually brings up the voice search. Never tried it until tonight using 2.4. Could try and re-install it maybe.
yeah, you might want to just try and delete the current 2.4 on your sd card, download again and install again. If not you can also check out JaeKar99's ROMs/Themes/Kernels thread. There is a link there for an EB01 stock, deodexed ROM with the long press search fix.
Thanks! I've really been looking for that. Haha
I was actually looking for an answer about whether there are now separate red clockworks for voodoo and nonvoodoo or the same new red cwm works on both when I saw the thread :)
Oh yeah, another thing. If you know, I'm still on green CWM. It works fine. Are there any reasons for me to switch to red?
How are you still on green cwm? you shouldn't be able to flash anything with it, it is not compatible with Froyo. When you go to menu=>settings=>about phone, what does it say for baseband and build?
Question. If i want to go from SC 2.1 to SC 2.4, do i need to go through 2.2 and 2.3? Or can I just go straight from 2.1 to 2.4? Also, I install that via Red CWM, correct?
Thanks in advance!:)
My Baseband is S:i500.04 V.DL09 and my build is SCH-I500.EB01
That is correct sir. You can go straight to 2.4 through red cwm. Flash away.
Reactions: Les3631
Status
KaW
