We are the old Dogs now, stuck in limbo. Liking what we have and waiting for something to top it...![]()
Amen.
After experiencing the horror that is the EB13 video camera, I think I'll be coming back to TER.
I've seen that a few people are running TER with the genocide kernel, maybe with a few issues. Is anyone running genocide v0.2a with TER 1.5 with no problems?
EDIT: Wow, apparently Sprint and/or Samsung took down the EB13 update due to the issues people are experiencing:
Sprint Community: 2/21 - Samsung Epic Maintenance Release...
It is required that you have a Froyo DK28 system with an EXT4 filesystem and ClockworkMod Recovery v3.0.0.X before flashing this ROM
Ok, quick question on this statement and how it relates to the clean install version of TER 1.5:
If I'm coming from official stock EB13 (RFS), and I want to use the TER 1.5 clean install, do I still have to convert to EXT4 and install CW v3 first, or will wiping and flashing the clean install take care of all that?
Yup, no problems. I'm running at 1GHz and battery life for me went from about 16 hours to over 24.
I assume this is what you are using?
[KERNEL][GPL]Genocide 1.2GhzOC EB13 Kernel v0.2a (DK28 Compatible) - xda-developers
Forgive my ignorance, but I saw no instructions on installation. Is this flashed through CW3?
Yeah just download the zip, transfer it to the SD card, and flash in CWM3. Probably a good idea to do a nandroid backup first, just in case.
So i did the zip file update yesterday, upgraded from stock and i am not impressed with EB13. From what i am reading people are prefering TER over EB13. So i would like to root my epic and give TER a try. Do i need to go back to eclair first. Not sure where i should start.
thanks in advance.
