[ROM][WIP][PORT]Paranoidandroid from optimus one to optimus s
3G should work from replacing the build.prop
Replacing those 2 files, I wouldn't recommend because Paranoid made it for there rom with all the DPI's.
Reactions: vernotzy21
Here's a log cat yo iv noticed that the adreno200 something isn't quite loading right
Notification menu is off
Es file manager graphics are displayed incorrectly
Logcat
http://db.tt/MM9vHfXc
Also affects market as well
Sent from my LG-P500 using Android Central Forums
Been using it like that since I posted the "fix", the build.prop itself did not fix the problem. The signal indicator stayed grayed out with a X in it until I replaced TelephonyProvider and Phone.apk. Even tested it afterwards and com.android.phone no longer force closes, the DPI seems the same as it did before replacing it.
Also, I didn't originally port the ROM, but logcat was asking for a com.android.GSMPhone which would not work on our phone since it requests access to a SIM Card that we don't have.
On another note: I sent the OP a PM asking if I could learn his steps to porting this ROM in case he abandoned it. I'm very happy with it and would love to continue it in my spare time.
This port works with Cdma ?
http://forum.xda-developers.com/showthread.php?t=1742999
Since my esn is no good I use it for wifi only so I'm good with that I wanna make fast and comparable
Maybe we could replace components from this build I only got my Droid so I can test
Definatly something withe sprites?
I wish I understood how this roms graphics engine worked compared to other roms by looking at the log cats I'm guessing it loads more drivers?? And one isn't loading properly?
Sorry bout the long post but iv just "doin it" today:p
In the LCD resolution app I'm getting dpi settings of 42-102 dpi
And resolutions of 278x266 to 918x647 and not even 480x320 witch is native? But I just replace build.prop
Rebooting
OK I'm back still same as reported above however my keyboard sound FX seem clearer:confused:
Anyway maybe make 2 builds one that tackles GSM/cdma issue and one that is strictly wifi removing 3g data focusing on stability/ compatibility allowing for a cleaner smaller build
Hmmm a wifi only tablet rom for us deactivated folks
[ROM][PORT][GSM/CDMA] Paranoid Android v1 Based on CM9_FXP127[update 01.07.12] - xda-developers
Click to view quoted image
Rebooting
You can remove the 3G indicator, but in a phone-based build, TelephonyProvider and Phone.apk are ones that shouldn't be removed. Also, replacing everything I still have my Tablet UI. I can upload a screenshot to show if you guys want.
Also, that ROM's for ARMv7. That would be a no-go. The OP still hasn't replied to my PM though, if anyone can help me with porting this ROM, I'd gladly appreciate the help (I just need help with the first time).
that would be cool
TheKravens cm7.2. 3.7
amphetimines
kodev ics theme
787 MHz
smartassV2
Ill port it and post a test here. The OP apparently ported wrong.
Mind PMing me when you get it done, would love to try it and I don't get to check AndroidCentral often anymore due to not having power at home. But I LOVE ParanoidAndroid.
By the way, this is ported from the Galaxy Nexus to the P500 tp the Optimus S.
UnknownArtist cares as well. He wants a fully working one for CM8.
ali5505
