my wifes phone has been reborn by this rom, I think even she was ready to throw it out the window.
Thanks, Great work.
Thanks, Great work.
It's recommended to flash the latest ginger kernel afterwards. That should fix the screen glitches
I'm having a lot of screen glitches after fresh install. This persists after reboot. I tried changing the clock speed with no improvement. Wiped and reinstalled with the same result. No improvment after installing the latest gingerkernal.
Not sure what else to try. I was previously using opti-rom v1.1
Thanks for help
where does one find debug-format SYSTEM.zip?
What exactly you you mean by "screen glitches"?
The screen image is distorted and flickers in and out of normal
No, sorry. I didn't see the 8.1 update.
I am using the v08 version.
The screen glitches were fixed for everyone (except you apparently) in v08. That makes no sense why you are experiencing them. Are you overclocking? And if so, at what CPU frequency?
I would recommend a full wipe including the debug-formatsystem.zip. flash the rom then boot into android. Let it fully load then boot back into recovery to flash the kernal.
Meaning delete debug-formatsystem.zip or flash it prior to flashing rom? By the way, using v08 with opti-rom and no glitches.
