Samsung.com S10/+: Pre-Order Thread
Still waiting for drop off at my job. At least it's on the vehicle for delivery today.
Re: Just gotine today!
Found it!
Settings - Notifications - Status Bar - Show Battery Percentage
Stupid AT&T put a piece of plastic film over the pre-installed screen protector that Samsung put on. And they put a hole in it where the fingerprint sensor is. Lmao.
Do you know how much time they give you to trade the device in? I'm trading in my Pixel 3 XL but want to make sure I actually like the S10+ better first.
"Anticipated trade-in value will be applied as a credit at time of purchase, but, if you do not send in your trade-in device within 15 days of receipt of your Qualifying Purchase, you will be charged back for the trade-in credit applied to your purchase, or if you send in your trade-in device within 15 days of receipt of your Qualifying Purchase but Samsung determines your device does not meet all eligibility requirements, you will be charged back for the trade-in credit applied to your purchase minus $25."
No movement yet on my order from Samsung.com.
Delivered! 452MB T-Mobile Update...now I gotta factory reset and start fresh ;)
Already loving not having to click OK after entering PIN. New notification sounds are much nicer, and vibration motor is much tighter.
Did you just "skip" the setup process, download the update and then you factory reset it.?
NO..it didn't find updates over wifi before I put my sim in....I signed in and updated apps and then checked for updates AFTER I put in my sim card, then it found the TMO update.
I like to start fresh, so after installing the update, I factory reset 2x just to clear everything out with the latest core software.
So some early thoughts, I absolutely love love love the earbuds..
Where did you get the UAG Pathfinder case? I'm digging it, even though I don't want to cover up the ceramic white back...
kitlis
