Samsung Galaxy S3 charging issue
Hi I have a rooted s3 and was having the same problem too. It would charge to a 100% then once of the charger it drops at an alarming rate. Have changed the batt but to no avail. It's also not holding its change at all. 100% drops in a matter of hours and when battery stats are checked it says screen usage even if I ain't using it. Running out solutions. Anyways hope u solve your problems, I know I haven't though.
This worked for me, at least so far. I have been weeks with no charging battery while in phone, having tried multiple batteries and multiple chargers/cords.
I am having the same issue, I went to Samsung's chat support, this is what I was told, and this was actually the name of the person I was chatting with.
Shaniqua: Please perform the below steps:
Shaniqua: 1. Power the device off (remove and re-insert the battery).
Shaniqua: 2. Press and hold the Volume Up key and the Home key, then press and hold the Power key.
Shaniqua: 3. When the device vibrates; release only the Power key.
Shaniqua: 4. When the Android system recovery menu displays; release the Volume Up and the Home key.
Shaniqua: 5. Navigate with the Volume keys to the 'wipe cache partition' option and press the Power key to select.
Shaniqua: 6. After user data deletes, press the Power key to reboot system now.
Shaniqua: As we have performed with wipe all cache, I request to charge the device upto 100% and observe the device, if the issue persists, you can get back to us, we will be glad to assist you 24/7.
I hope this works, my phone is currently charging up to 100% and it seems to be fine so far.
i was having crazy charging problems. would charge to 100% then immediately drop 30 or so % when i took off cradle. i instead tried a different cable on cradle and for the past few weeks on issues.
I've had this problem, taking as much as 18 hrs to charge to 100% I changed chargers but still had the same problem, from 5pm yesterday to 9am this morning and it was only at 68%, but went down to 67% while using it, so then I tried my wife's charger and it worked fine, went from 67% to 100% in less then an hour.
I hope this helps.
Regards
Derrick
I hope this helps.
Regards
Derrick
same issue im having been on charger since 11 last night & only at 67% percent almost 12 hrs later
I don't think you can say it is 100% usb/charger issue. I recently started experiencing this charging problem. The first thing I did was try different usb chargers. 4 different chargers. None of them make a difference. For me it is 100% NOT the usb problem.
I am wondering if that worked for you? because I am having THE exact same problem. I even replaced the battery and got a new charger which worked for about a month and now I am back to the same issue.
I am having the same problem
Which 'same' problem are you having - a charging problem (like most of the posts in this thread) or simply that your screen won't turn off while charging? If the latter, have you looked in Settings -> More (if using the Tab view) -> Developer options, and verified that 'Stay awake' is unchecked?
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
Here's what you do: Make sure you have some time. Basically, stay on the phone with one person. Don't let them transfer you around from department to department. Wear them out with kindness. Basically, you're hoping they'll budge. You're hoping they'll find it easier to just give you what they owe you, rather than to stay on the phone with you. You prove to them you're smart. You're not giving up. They'll eventually see, if enough people do this, they're wasting far more on customer service phone calls than they're making back by denying repairs. Follow a script like the following.
First, get the name of the representative you're speaking with. Establish accountability.
Ask them if they can be who you speak to in future regards of the conversation. (otherwise they'll transfer you all over the place)
Ask them which department they're in. Which location. Joke around. Talk about the weather. Establish good rapport and be respectful to them. Don't raise your voice or get angry. If you do, it will only hurt your chances.
Say; Have there ever been exceptions made by the technicians to reevaluate a phone that has been declared BER? If so, what exceptions have been made in the past? If not, Would they ever consider making any?
Could there be instances when a phone appears to have been physically damaged even when it actually wasn't? How does your warranty account for such instances?
If necessary, tell them which service ticket ID it is regarding. Continue asking questions. Say:
I've read about other people experiencing this same issue. I wanted to make sure I wasn't the only one. I know you must deal with a lot of angry people. And people who aren't being honest. So, I understand your pain. But unfortunately, it's an inconvenience to me because those dishonest customers have made a bad name for all customers, even though I'm not like them. I'm not angry, nor am I dishonest. So, if possible, please try to see that I'm not your average upset person. Rather, someone with the unfortunate circumstance of having a phone that has unexplainably stopped working.
If it's beyond economical repair, would Samsung be able to replace my phone?
Being that this has been a common complaint among Samsung customers, and being that I haven't physically abused my phone, is there any way we could meet in the middle? Perhaps you could trade my phone in for a refurbished phone?
Being that there appears to be some doubt from your technicians about the validity of my complaint, perhaps you could offer me a less expensive phone in place of my phone. Perhaps Samsung might be willing to offer me a replacement phone of an older version. Anything would be better than having nothing. Perhaps an S2 or a phone of lesser value?
Perhaps Samsung might agree to pay for some of the repair, being that it's your warranty that is partially at fault?
Are there any other ways that Samsung will meet in the middle for its unsatisfied customers? Perhaps a special offer or a discount in the future?
Would Samsung be willing to consider creating some type of offer for its customers who are dealing with this same problem, being that there are many of us, representing a large portion of potential future business for your company? Perhaps not a repair, but something else as a gesture of good faith on your end that you at least hear our concerns and are willing to give us some benefit of the doubt? By that I mean, could you perhaps offer us some type of points that can be used towards other Samsung products?
Keep offering them alternatives that are more difficult than actually repairing the phone.
Maybe if you can't help me here today, you can personally be my advocate with whichever department within your organization that can be of help?
Ask your rep: Who can you talk to personally to see that this issue is being addressed? Can you talk to the repair technicians personally?
Can you please bring this matter to your supervisor? I would appreciate knowing that the customer's concerns are being taken seriously.
Would it be possible to have 3-way call? Maybe a conference call with whom it may concern? If you yourself feel powerless to help me in this matter, isn't that a valid concern of yours? Perhaps you can bring that to your supervisor's attention? (Again, be patient and professional).
Say; I've talked with a lot of angry people about this. Many who unfortunately won't be buying Samsung products again. I know you care about your business. And for your company's sake, it's important to know which customers concerns are legitimate and which aren't. I know many of us feel we have legitimate concerns, and we aren't being heard. And, it's not an isolated incident. Rather, a common problem. One that might suggest a recall could be fought for by consumers if enough of them were to unite in pursuit of it. I know some who have gained interest in class action suits, who would be glad to have me on their side. Also, those who are trying to build interest in bringing this matter more attention publicly, as well as to the Better Business Bureau. But I don't believe in taking legal actions right away. I much prefer to try handling issues a simpler way, which is what I'm hoping to do now. I trust that the company will be reasonable once it has heard my concerns. Good reputable businesses usually care about their customers' complaints, and a large business like yours depend on a good reputation to stay in business. So, I'd like to know that in your organization, my matter is being heard. By you, but also by whoever it may concern. I would like to stay in dealing with you about this matter, as I also continue to deal with whoever else in the company I can speak to regarding this concern. You and I will be in close correspondence about the matter. My concern (as well as many of ours), is that we feel there is an error in the warranty, voiding Samsung's obligation to repair items that they should be obligated to fix. Depending on how you choose to address this concern of ours, could do your company either a great service or a disservice. I personally would like to be able to say our talk today went well, and that Samsung is a reasonable company. I would like to be able to say to other potential customers of yours that there is hope when dealing with your company regarding these discrepancies. I want to believe that the rumors I've heard are false, and I want to know I can stop them from spreading further, but before I can do so with good conscience, I need to know your company is a reasonable company. If you can convince me of that today, I'm sure I can convince others the same. I just need your help to do that.
If it would be of help in your convincing, I'd be willing to sign a legal affidavit stating that I haven't abused the phone in any way. No physical abuse or exposure to extreme temperatures. No water damage, etc.
I paid for a phone. It stopped working. I trusted that your warranty was valid. I still do. I believe my phone is an exception. It somehow slipped through the cracks of your system. That's ok. Accidents happen. Now, the next step is fixing the issue. What is Samsung willing to do to in situations like this to uphold its reputation?
I'd like the technicians to show me evidence that the phone was abused. Do they have pictures? If not, I'd like to see pictures. I'd be willing to send my phone back in so that they can reevaluate it and take pictures.
Can I find out which technicians are responsible for determining whether a phone is BER?
Could I request to have an investigation done on that technician's department, being that there are many of us who feel they aren't doing their jobs sufficiently?
How does a technician confirm physical abuse? (who would be able to tell me? Can you contact that person for me?)
Can you explain the warranty to me? I'd like to know where in the warranty it voids my phone's repair, and how it determines whether a phone is beyond economically repairable.
Which location declined my request to have the phone repaired? (who would be able to tell me? Can you contact that person for me?)
If you can't personally get my phone to be repaired, can you please have our current conversation submitted to your quality assurance department for evaluation? (If not, who would be able to do that? Can you contact that person for me?)
Also, if you can't help me today, could you find out who can?
Is there a reference number for our conversation today? Can I have it please? Who can I speak with in order to review your job performance in assisting me today?
Reestablish accountability. By now, you've been on the phone with them, whittling down their defensiveness for an hour or so. Hopefully, they've decided to budge. If not, keep going. Don't let it be easy for them to get away with this.
The end.
I've read all the posts here but my problem is slightly different, and interesting...I bought my wife a second hand Galaxy s3 and have the same phone myself, her phone won't charge or go into charge mode (light on when screen off or with screen on little lightning bolt in battery power icon) with any but one charger...it is a samsung charger being the type with the usb cable that plugs into it.
I have four more original samsung chargers that are basically the same but none charge her phone and all of them charge mine, I also have six or seven cheap or non samsung chargers, none work hers but all work mine, I today bought a couple of in car chargers (again the type the usb lead plugs into) both work my phone but niether one work hers...I tried the usb cable from the charger that does work her phone in the car charger and that didn't work.
The chargers fit snugly and click in nicely, a couple of the cheap ones wobble a bit as they do in my phone, I really can't see what the problem could be.
I have reset it, I've used samsung kies and upgraded to the latest software...it charges fine on the pc usb with any cable.
I really need her to have an in car charger as she does a lot of travelling and I am worried that if the one that works her phone fails or she loses it I can't think what the solution would be.
Any ideas would be much appreciated.
Thanks in advance.
Chip
with any but one charger....it charges fine on the pc usb with any cable
If I've got this all correct
- her phone charges fine using ANY cable when connected to a USB port on a computer
- her phone charges fine using ANY cable when connected to one specific wall transformer
- her phone will not charge at all using any other combination of wall transformers, car chargers or cables
That's pretty strange. What's the output current rating of the one transformer that her phone works with? 0.5A?
Since you got it used, I suppose it's possible that the previous owner had the micro-USB port replaced, and that whoever did it missed something - you could try getting it replaced and see if it corrects this strange behavior (ex. http://mobiletechvideos.mybigcommerce.com/samsung-galaxy-s-iii-usb-port-repair/)
Just for the record: My wife's phone had this problem - charging getting slower and slower, even when powered off. I assumed a new battery was needed but it made no difference. Then I read this thread and saw that many people had had success by changing the USB cable. I tried a different cable - same charger - charging rate was restored to normal. This may not be everybody's solution but it has clearly worked for a number of people.
Since you got it used, I suppose it's possible that the previous owner had the micro-USB port replaced, and that whoever did it missed something - you could try getting it replaced and see if it corrects this strange behavior (ex. Samsung Galaxy S III USB Port Repair -)
Right this might help others who have these phones that don't see the charger when it's plugged in, it still seems odd but here gos.
I took the back of my wifes phone and my own (both s3 phones) took both batteries out and I got a test meter and put one test probe on each of the two little terminals to the side of the battery (the ones the little receiver connect to if you get the wireless receiver that stands on the chrager pad) and I lined up some different chargers...3 genuine samsung of the type that the USB lead plugs into the plug that gos in the socket on the wall and the USB lead then gos into the micro USB on the phone,1 after market version of these, 1 genuine Samsung that has the micro usb for the phone and the other end built into the plug, three after market versions of this, two in car chargers that have the usb socket in them so you can use the usb to micro usb lead as you would in the pc usb.
Any USB to Micro USB lead in two of the original samsung plugs gave a power reading at the two terminals I mentioned, and I tried seven or eight different leads, all of which also worked in the pc USB port, the same leads in one of the after market plugs that accept the USB Cable, the same leads in both car chargers showed no current at those two points whatsoever. all the fixed to plug chargers again showed no current.
All the above options showed slightly varying amps on those points in my phone and all worked my phone peffectly.
I now see that some how the plug end is powering the USB to Micro USB differently in some of the plugs, it sounds odd and I have looked into wiring diagrams on the net and can't understand it but if I leave the micro usb plugged into the wifes phone, take the USB out of the plug that doesn't work it and put it in the one that does it is fine, that tells me the fault is not the phone end, leave the USB end in the plug that doesn't work hers and take out the mini USB end from the phone and put it in mine...it works.
My Daughter turned up last night and I tried her cheap car charger in my wifes phone with my any USB to Micro USB lead and it works on her phone, my phone and with a diferent lead my daughters Iphone.
This tells me that somehow my phone is taking power in a possible two different pins in the port, and my wifes only on one, it seems that some of the host plugs for the USB lead power in both of those pins and others only one which must work the majority of things using power through a USB port.
I realise two of the leads are for data in and out and that USB is four wired but USB micro apears to have five wires.
I can't explain it any other way but even my own explanation (and I'm happy enough now with two working chargers and a working in car charger) why two identical samsung galaxy s3 phones should be different in any way in the way they charge.
Long post I know but its all spot on an I'm not trying to lead anyone wrong here, remember though this wasn't a slow charge problem, it was the phone not seeing about 90% of known to be working chargers, it by the way has no play whatsoever in the socket.
Cheers for the replies and I hope this helps someone.
I'd disagree with your analysis - seems to me that the problem is in the charging circuit on her phone, or in the micro-USB port itself. There is different signaling on the line that tells the phone whether it's connected to a standard USB output (0.5A) or a wall charger (0.9A). It seems like the phone is correctly interpreting the lower amperage signals but not the higher signals.
Have you closely examined the micro-USB port on the phone to make sure all of the contacts are properly aligned, and sticking up at the same height?
You could try cleaning it out with electronic contact cleaner and a toothbrush (with the battery out of the phone of course).
If you have $ to throw around, it would be interesting to purchase a wireless charging solution (to completely bypass the micro-USB port) and see if the phone charges correctly.
Just my $0.02
I bought a used Galaxy music player from Cowboom and when I tried to charge ... same problem wouldn't charge. Borrowed my coworker's phone charger and ... no problem.
So definitely try several USB cables. Perhaps Samsung needs to give up on the convenience of micro USB or find a different suppler. My Galaxy tablet has a big-*** charger with a 400-pin connector and no problems.
Oh, my mom reminds me ... thanks for your help!
No the problem isn't in the port, well as far as I can see anyway, its like brand new in there and why would a problem in the port on the phone correct itself if you leave the same lead plugged into it and change the plug on the other end?
Any charger that works with her phone shows the same amps on the two terminals I mentioned (where the wireless receiver would attach) its not an amperage issue as it works with from one that (as mine does) reads 0.5 to one that reads 5,1. as I say thats three different ones working with hers and I just tried it in a charging dock, the type that the phone stands on with the micro usb standing up going into the phone and a flap behind that will charge a spare battery, on the back of the dock is another micro USB hole and low and behold I can use either of her plugs that work on it and it is perfect but if I use one of mine....you guessed it, it charges mine but not hers.
It is a strange one but really is now of no concern to me as I have plenty that work it now, I just hope if anyone else has one that doesn't recognize a charger at all, even though they try that charger in another identical phone, they don't give up until they try as many possible.
And take the phone back off, remove the battery and check for current on those two little gold terminals, it really isn't relevant how much current as mine charges on a wide variation and always fairly quickly while my wifes as long as they are showing amps charges just as well.
Cheers for the thoughts.
I can't believe it, it worked!
be warned, you have to do the tongue trick, and then restart the device, otherwise it won't work
thanks man you are a genius!
My phone wont charge at all but I need it.. its going to die and I need help any ideas what I can do?
ameliadinkins
