Sprint S3: Wicked Sensations 5.0
Re: Wicked Sensations 4.1
Hey SeanskiT1,
I installed yesterday and the rom is NICE!
By the in the day an app called LMT has stopped working..
Everything else works good. I just need LMT to work again.
Any Ideas?
Thanks.
Flashing themes on other ROMS has nothing to do with flashing themes on WS. This is what I recommend you do:
1. Make/have a good backup with TWRP and ensure it works
2. Do a full wipe and clean flash WS v4.2
3. Reboot and sign in
4. Go into The Kuban Updater app in your app drawer and in the themes section download Twisted Pink v4.2
5. When download is completed select "no"
6. Boot into recovery and wipe cache and dalvic only
7. While still in recovery, hit install and in the kubandownlads folder located in internal storage select Twisted Pink v4.2 and flash
8. Reboot and enjoy!
Sent from my Nexus 10 using AC Forums mobile app
Thanks For the suggestions on how to get this to work.
Kuban is still not being recognized in TWRP, so i just downloaded it to my computer and loaded it to my SD card and its working just fine now... SO all is good and however it got done its working and is installing now.
Thanks now to just figure out what i like better This or the hello kitty theme I had on CM 10.1. :) Thanks for your help.
Hey SeanskiT1,
Any Ideas?
Thanks.
Can you be more specific about this app? Is it a system app or one that came with the ROM? Is it one you downloaded, I don't see it on my phone.
sent from my GS3 running Wicked
I had restored it from my other Rom. LMT was working fine until later on.
Go settings and click on Accessibility and you will see LMT and 1tap quick bar.
I also restored 1tap quick bar from my other rom.
Make sense??
Thanks again.
Since flashing this new version of WS my Samsung Link doesn't work anymore. After booting up the phone freezes and I get and error saying it stopped working. It does this twice. When I try to open the app nothing happens. I restored the app from TB along with everything else.
I actually use this with my TV a lot so I'd like it to work again.
Sent from my Wicked Red S3
Try deleting it via titanium and then going in the Play Store and downloading it.
Sent from my SPH-L710 using AC Forums mobile app
Did you do a clean install? Factory reset, wipe cache & dalvik?
Make sense??
Thanks again.
Still looking into your issue
Yes, clean install, reset . I will try Keith's suggestion and see if it works.
Make sense??
Thanks again.
Are you refering to this http://forum.xda-developers.com/showthread.php?p=18993800? If so try unistalling with TB & re-downloading.
Uninstalling through titanium and then installing from the market worked.... Until I rebooted. Does the same thing again. I did not have any problems until updating to 4.2. Is there something new in the ROM that could be affecting it?
eRedicate v4.2 is now available. Still not available in the updater so one can either wait or go to xda.
Have you deleted Samsung Link with Titanium and then backed that up, clean flashed the ROM and checked it? If that didn't work then went to the Play Store and downloaded it? I'm not saying that this would solve your problem, but it's a trouble shooting thing I would try.
I'll try that method after work later. After I got it working I flashed anakonda 4.2 and then it stopped again. I keep getting the errors that Samsung link has stopped working every time it wakes until I delete it with titanium.
It appears as though you are not the only one with this issue. Dazed is working on it.
Dazed has resolved the Samsung Link issue. Head on over to the updater and under "Bug Fixes for v4.2" you will find the "Stock Samsung Link" zip.
Happy 4th of July everyone!
gurusdex
