Sprint S3: Wicked Sensations 5.0
Re: Wicked Sensations 4.2
Rumor has it after Google pushes out their updates Dazed is going to update the ROM. It may be in a couple weeks.
Sent from my SPH-L710 using Tapatalk 4
Re: Wicked Sensations 4.0
How do I change from the red theme back to the original.. Red is the bling at night, but real hard to see in the day time..Thanks
What's with the purple play store theme? Will there be an actual theme using purple or is it just the play store?
Sent from my Wicked Red S3
I am having a lot of phone connection issues since upgrading to 4.2.
Is there any way to know what modem I am running?
and should I be run one instead of the other or it is just which one gives me the best phone reception
If you go to settings then about phone, that will show which build. Look at the last 3 letters. The most current is MD4. That doesn't mean its best for your phone & area. If you are on wicked, you can flash the other modems from the kuban & try them out. What kind of issues?
sent from my GS3 running Wicked
I just switched to MD4 a few minutes ago.
my phone drops calls cuts in and out
the signal goes from 3 to no bars.
can't talk to anyone...
Like I said you can flash the other modems in the kuban. Also you could try wiping cache & dalvik in recovery. And also you can reset data by dialing ##72786# on your phone dialer. When you updated did you do a clean install?
The modem is fine. You have to remember...You're using the Sprint network :p
How do we enable Google location history on the WS 4.2 rom? Nothing in the location settings in the menu that match to any of the Google instructions. Any help is appreciated!
Beta of 5.0 available for dl. Follow links in op and go to post #9020. Don't worry it is awesome as usual.
The 5.0 beta is running like a champ for me.
Official version of 5.0 is live. Just click the link to go to XDA for download.
And with the rumor of JB 4.3 rolling out real soon, Dazed yet again, will get no rest, lol
Glaywinpe
