Xoom Boot Animation On Droid X
Actually I just got it!!! yay, great job btw. I dont know why but when i used stock android browser to download the progress of the download looked goofy but it would say complete. I used Opera mini and it worked great, 2 different file sizes between the different browsers. ??? ah well I got it!! and great Job again, I appreciate your help fine sir!!!
Sweet! Glad you got it going.
Sent from my DROIDX using Tapatalk
The only way I could get this to work was through Bootstrap.
Tried the other way and nothing. Oh well though.
Thanks tntdroid!
yup work for me too on liberty 1.5 . Already had the bee ha actually have the wallpaper too :p
How would i do that? lol sorry kinda new to this :)
dl the file in the OP that says drop in data local. Place this on your sd card. Using the app root explorer go into the sd card and hold down on the bootanimation.zip file you just dl. Then back up and go into data then local. The hit paste. If you have a file in that folder already you can just overwrite it. If when you boot it does not play go back into root explorer and go into system media. If you have a bootanimation.zip file here you can rename it to say .bak and not .zip. This is save the file so you dont delete it. You can always rename back to .zip and it will work again. The same can go for if the boot is in data local and you dont want to delete the stock boot.
Is there anyway to resize this animation so it looks more like honeycombs and less like diamonds, in another forum someone has resized it to better fit his D2.
tnt, is it difficult to port this to other devices? I would love to have this on my Dinc, or my NC (once there is a decent HC build out). Just wondering if it has to be totally rewritten or just resized to fit screen resolution? Thanks for all you help.
It would have to be resized and in the same format as the device. This will work for moto devices but I believe the dinc is a different set up and file name. The original images are smaller than the screen size of the x so its off in size. Going to rework it today and hope for better.
Sent from my Xoom using Tapatalk
maryhurst515
