Here is another GREAT AOSP ROM... this is not you typical ASOP rom though It is a fusion of CM7 and AOSP.
Here is DroidTh3ory's first AOSP build... Compiled from CM7 Source from the ground up, then torn apart to tweak, thin, and mod. It's SUPER fast, solid as a rock and fluid as it gets. ENJOY!!!
A05PTH3ORY V1.4X CM7
FULL CHANGELOG
V1.1
Newest Source from CM7 GIT (8/4/11)
Fixed Maps
Fixed GoogleTalk Video
Added Low Volume Tweak
Cooked in Pur3Ao5pStor3
Trimmed a little more fat
Edited GPS.conf (may help the few having a lock issue)
More Butter Baby!!
V1.2
Merged the latest source
Optimized ALL png's
Streamlined framework.res and systemUI
Updated Latest GAPPS and Framework
UI MODS for some flair
GPS.conf mods
DualMIC 1+2 Edits (Hope it helps)
Minor tweaks to hidden app Management
Fling scrolling is now on steroids.
V1.2.2
New Kernel (Modded Imoseyon 3.8.6 With InCall FIX)
Trimmed it down some
Automated Updater-Script
Included Speedtweak.sh
Pushed MEM (Task) Management to the brink of sanity (Enjoy Your Battery Boys)
V1.3X
Rebuilt From Source
Fixed Market
New MODDED DreamKernel 2.6.0 W/ Full Audio FIX
Minor UI
RAM Management Modifications
Trimmed SystemUI And Framework
Bumped up MAX Screen Apps (Fling Your Ass Off)
Ummm Yes, Even MORE Butter (Call Your Doctor)
V1.3.1
Updated Music
Few Edits for CPU Management
UI Changes
V1.4X
Fresh compiled source
Reverted back to Modded DreamKernel
Fixed GoogleSevices
Latest GAPPS
LTE Icon for DATA
Rebuilt Framework
Build.prop Changes
GPS.conf edits for faster lock
Fixed Maps
More Butter Baby!!
V1.2
Optimized ALL png's
GPS.conf mods
V1.2.2
V1.3X
Rebuilt From Source
Fixed Market
Minor UI
V1.3.1
Updated Music
UI Changes
V1.4X
Fixed GoogleSevices
Latest GAPPS
LTE Icon for DATA
Rebuilt Framework
Build.prop Changes
RADIO: Download The Radio. Either MR2, MR2.5, .627, OR MR3 (704)
IF GPS ISSUES... Try this ,My GPS works perfectly... .
here are some tips for you to get it working... let me know if you have tried any of these.
1. turn on GPS (under 'location and security" - select BOTH 'use wireless networks' and 'use GPS satellites'. then open the 'maps' app, menu and select GET DIRECTIONS. then enter in whatever end location you want and press the NAV icon (blue arrow). it 'should' open your nav app and work... if not, try this
2. leave GPS running on you phone and make a nandroid. after nandroid is done. restore one of you older nandroids that you know for a fact has working nav, when you restore it, turn on NAV and GPS. then go into ROMmanager and restore the nandroid you just made of this. that also, should allow you to use your nav and gps...
also, I use weatherbug and have to manually put in my location sometimes.... then for no reason, it will put me back in tennessee or somewhere crazy, and I have to go back and press menu -locations- and select the preset one that I made ealier...
AS ALWAYS - READ READ READ and RESEARCH... any issues or problems relating to this ROM should be posted to this thread. please do not make a new thread post keeps down clutter and we can help you faster!
I TAKE NO CREDIT FOR THIS ROM, JUST THE MESSENGER
ENJOY!!!
