Re: [ROM]COLD AS ICE-CM9 Sprint LS670 6/26 ZVD basesband Alpha16
I thought I would do a little test. I was curious why the tdm nightlies were working, but not CAI. I thought it might just be something else in the CAI build that changed enough to cause issues. I booted up into a15f, made a nandroid, then installed the a16 audio fix patch. I got the same results as if I had installed 16c+, I boot to Cid, and stay there.
So I opened up audio fix zip and compared the files in /system/lib/hw with what tdm has, and I found two files missing from CAI. I added them to the audio fix zip. That didn't work either.
So, now it's bedtime for Buddlespit. I have to work tomorrow, so someone else can take over and play around with this...
