Page 2 of 179 FirstFirst 12345 ... LastLast
Results 26 to 50 of 4464
Like Tree994Likes
  1. #26
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband on
    Quote Originally Posted by noonebutkev View Post
    A dirty flash is when you only wipe cache before flashing.
    The data is still pretty iffy because this is still in alpha, but you can try turning on airplane mode and turning it off...
    also, check out the Kravens cm7 thread, they talked about data problems over there.
    http://forums.androidcentral.com/lg-...-only-199.html
    i wiped everything and im coming from the kravens cm7 and had no problems
  2. #27
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    working after airplane mode thanks guys
  3. #28
    Christmas in February!!!
  4. #29
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Quote Originally Posted by wingedscorpion21 View Post
    true that
  5. #30
    tlrsax54's Avatar
    Posts
    ROM
    Stock
    Sometimes after coming off of Wifi or a reboot, my 3G doesn't connect but shows that it's on...I have to go to settings and turn Data off and back on and it connects...
  6. #31
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    do old titanium backups not work????
  7. #32
    Quote Originally Posted by tlrsax54 View Post
    I had the same prob.
    Turning data off then on fixed it to.
  8. #33
    tlrsax54's Avatar
    Posts
    ROM
    Stock
    Quote Originally Posted by jonny5449 View Post
    As long as you are using the current Titanium Backup it should work. I've restored several things (but there's not a lot of app room so you might not be able to restore everything.)
  9. #34
    me2151's Avatar
    Posts
    ROM
    CM10(u jelly?)
    data worksperfectly for me
  10. #35
    drewwalton19216801's Avatar
    Posts
    ROM
    HydroROM
    Just so everyone knows, I'm nearly finished porting the newer KGSL driver and the genlock driver to GingerKernel. I believe these are the final pieces of the puzzle for full H/W Acceleration. Stay tuned...
    Thanked by 4:
  11. #36
    Quote Originally Posted by me2151 View Post
    It is working good for me to.
    Right now its looking like it turns 3g off when you are not using it.
    casue i look and the 3g is gone until i start to use something to use data then 3g pops back up.
    So you couldn't resist testing it out could you?
  12. #37
    small bug.
    When typing on facebook, google+, and others, spell check says all my words are mispelled
  13. #38
    does Bluetooth work for anyone else because mine doesn't and just wanna make sure
  14. #39
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    Drew's CMX/Stock/Stock
    so to clarify, the mic fix also fixes the home button issue?
  15. Thread Author  Thread Author    #40
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    yeah it's a small patch till the next build. Plus you should gain room for gapps afterwards.
    Thanked by 2:
    noonebutkev likes this.
  16. #41
    Posts
    ROM
    HydroROM
    UPDATE:
    H/W Acceleration is a GO! Currently testing a new build of GingerKernel with this ICS build. Angry Birds Rio runs like a champ, as does the Launcher UI. Expect a build release soon
    EDIT: If you would like to preview the new kernel, . It's unsigned, so you'll have to turn signature verification off.
    Thanked by 5:
  17. #42
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    In settings --> launcher --> clicking icons and dock do nothing. I hear a click, and see the touch response, but it doesn't open any menu.
  18. #43
    prowlingfox's Avatar
    Posts
    ROM
    tdm's AOKP ICS
    Quote Originally Posted by drewwalton19216801 View Post
    UPDATE:
    Drew, does this next build include other fixes besides HW acceleration?
    EDIT: Also, can this kernel be flashed for the Cold as Ice ZVD rom or just for the Hydro ZVH CM9?
  19. #44
    noonebutkev's Avatar
    Posts
    ROM
    The Kraven's Cm9 Alpha2
    UPDATE:
    you just flash from recovery right?
    nevermind, i got it...Thanks drew!
  20. #45
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Codename Android / franco
    UPDATE:
    Holey moley, this is awesome. thekraven ics and now this afterburner. wow, Wow, WOW
    Buckle in, sit down, hang on!
    Yes
    Galaxy Nexus GSM
    RasBeanJelly JB 4.1.2 (JZO54K) ROM | Trinity Kernel A67
    i9250 UGLH1 Baseband | Seido Active Convert case
    T-Mobile $30 / 5Gb / 100 min Cellular | CSipSimple + voip.ms VoIP
    Kindle Fire
    ROM - Jelly Bean using SGT7 enhancements [Linaro]
    "My Kindroid Jelly Fire Bean"
  21. #46
    pdxguy77's Avatar
    Posts
    ROM
    HydroROM 1.1.0/Hydro v1p4
    installed and so far am very impressed. data and wifi work. moving from screen to screen very fluid. youtube FC's but dont normally use it anyways. keyboard is small. i really like the htc_imod keyboard from hydro rom.
  22. #47
    pdxguy77's Avatar
    Posts
    ROM
    do have low memory problems....am looking forward to the next update to slim it down
  23. #48
    pdxguy77's Avatar
    Posts
    ROM
    holy crapola my S is on crack after the kernal upgrade. will it have the same side effect as a regular drug user and crash hard afterwards...lol...awesome work you guys...i wish i had the patience to do a rom...
  24. #49
    Posts
    ROM
    HydroROM
    Quote Originally Posted by prowlingfox View Post
    No, it does not.
    This kernel will work in both ICS ROMs, and will work in all stock-based Gingerbread ROMs too (not including CM7 yet).
    Thanked by:
    jcruckus likes this.
  25. #50
    Invincible Madness's Avatar
    Posts
    ROM
    MIUI GB
    Building mainly for references, but I'm in a teaching mood, so ask if you want to learn.
    And I'm in a learning mood. Do you have a gtalk ID I can have? I want to know what are the requirements for building a ROM. If it sounds too much to start with, I'll start with theming. I'm free for next 5 months
