[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 3/20 ZVD basesband Alp
I haven't had some of those issues, and I haven't heard of anyone else having them either
HINT: Restoring data when upgrading from CM7 to CM9 does not work. I didn't think it would, but I didn't know for sure until I tried. Really borked CM9.... :p
I've had the voice mail issue
No matter what I do, a notification for 6 voice mails stays in my drop down.
Anyone had luck with MMS? Mine is still a no-go on a6
5. When listening to music i get no bass sounds...low frequencies...DSP Problem?
I don't think this has been brought up yet, but I noticed this too lol. I hook my phone up to my car and I thought my speakers were broken for a while lol...
I use my phone to plug into speakers at work and no bass, nandroid 7.2, back to the bass. For dubstep this is a must :-) kraven please bring dat beat back, also all these issues are found after clean install total wipe before I install programs, hard to believe no one else has noticed some of this stuff. Well just trying to contribute to the cause.
In cm7 you could just unchecked voicemail notifications. I can't find that option in this one.
Funny, I have not noticed those problems since I do not have them. All the problems you mention do not happen. Bugs are repeatable by many, so far you are the only one.
from LG-LS670 w thekraven CM9/ICS & Tapatalk
My bass is fine, both in the android music app and GMMP. :confused:
I, too, got "da beats" fine. My problems have pretty much gone away with alpha 6, other then MMS. Camera preview, and data connecting on initial boot are the only 2 major bugs left. Even my HD youtube is smoother. Data can be a bit wonky, but im sure that will get better as well.
@thekraven, i opened the APN settings and noticed we only have the one for Sprint. Is this correct? or should we have 2, like previous alphas? is this why MMS is broken?
Data still cuts in and out for me. But hey it's progress. Also, every time I try to save an image from the nets, i get "download unsuccessful". Boo hoo :'(
Running alpha6. Detailed assessment tonight; things going well enough at the moment.
If you guys get tethering working, I will switch to it permanately.
can some one put up a link to gapps 3-4 pl for us that cant find
Droid sail apps2sd root will let you move all apps including protected apps to sd you can find it in the Google market. Hope this helps a lot of people.
Kraven, you are awesome, just noticed that your init.d support works now :D I can finally start just making sure that the A2SD Mods have compatible binaries before releasing them instead of going through the trouble of making a whole ramdisk modification.
Sorry, I can't find the post. What was the solution for mms not working, cuz I got one and it wouldn't download. So I downloaded go SMS and it wouldn't work
So your saying you got google voice to install with no problem? It retrieved your phone number sent you the text to verify your phone? Interesting as it will not with mine. Don't know what I am doing wrong since I get these bugs but you get none. I make sure to wipe everything including the partitions in recovery, flash rom as usual. I don't know I will nandroid back and forth till wifi tether is a go. Just seems odd, this is not my first time around to flash a rom...been here for a while now. Don't think I am just going nuts and imagining these things. It's no big deal I am sure kravens builds will smooth out. He's my favorite rom builder out there =] Thanks kraven for your hard work and dedication to this phone! :)
Every phone is different. Gvoice works fine with me. Doesn't mean you did anything wrong.
Brabian
