- 02-17-2012, 03:18 PM
Thread Author #1
[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
CM9 Alpha build for Sprint optimus S
"COLD AS ICE"
ZVD only, but ZVJ works with the conversion patches
These are public test builds, so expect bugs. Test away and report bugs and what works for you. ETA's does kill puppies. So don't.
What works so far in CAI
Calls, 3G, wifi, gps, sms , MMS, camera with preview, video camera limited capturing, native usb, adb ,.headphones no mic, Youtube HQ works, HTML vids working. CM9 themes. Gmail whitescreen fixed.
What works so far in Paranoid android Tablet CM9
Calls, 3G, wifi, gps, sms , MMS, camera with preview(alpha10), video camera with videocam illusion from the market, native usb, adb ,.headphones no mic, Youtube HQ works, HTML vids working. CM9 themes. Gmail whitescreen fixed in 11/30 build More info here paranoid android info
Features
- USB fastcharging kernel
- Centerclock
- status bar tranparency
- i/o scheduler settings
- circle battery
- apps to sd-ex
- recent apps switcher
- navigation button options
- hardware keys action
- partition info screen
- EGL tweaks applied
- Root Browser file manager
- zip aligned
Not working
Video playback in gallery. Use quickpic or install mx video from the market. native tethering
BUILD CHANGELOGS
ALPHA 17 Panoramic camera fixed, not as fluid, but works, new test18 kernel with deep sleep fixes. Trying a few patches for clock sync issues. Gmail blank screen still has issues, but working on it. Center clock patch added. CPU rendering disabled thanks LeoLawliet. Transparency patch added. Custom key longpress functions added. ALpha 17F includes new usb fast charge kernel. See post 2 for more info. Slowly adding in blank gmail/fb fixes. Fixed Camera selection icon overlays. Reduced Font folder size. Alpha 17G , new audio routing...test for notifications playing in the headphones... Added home button answers call option. Fastcharge kernel and fastcharge toggleswitch options. You will need to flash the 17G fastcharge setting patch below. Comes with Test 19 kernel.
ALPHA 18 .
- More gmail whitescreen fixes... aosp fixes getting patched.. maybe next release.
- Added Fastcharge toggle to the notification drop down. .. Remember to turn it off/and replug the usb to use mass storage.
- Sprint VVM 9016 fixes.,Nav bar buttons and option,Circle battery mod and Line battery
- hq youtube fixed thanks to ganster and omxcodec.. fixed software decoding of Youtube HQ vids.
- adding in gmail whitescreen fixes from oxygen... not finished.
- test 23 kernel. Seems to suffer clock lag, flash test 21 kernel as a temp fix
ALPHA 19E
- Gmail whitescreen fixed version1 thanks popdog123. Same fixes as in Oxygen rom. It might make some apps incompatible, so report if any.
- Apps to ext and dalvik cache to ext option in performance settings thanks Nobodyatall. Choose a2sd for only apps moved to sd-ext. Reboot to take effect. Choose d2sd for dalvik + apps to sd-ext. Reboot to recovery and wipe dalvik. You may need to manually delete the data/dalvik cache folder. If you like the old way of automatic app to sdext, swap out the init.d folders from my old builds.
- I/o Scheduler settings
- recent apps switcher ported from AOKP
- html vids in webpages should be working thanks ganster41
- if you had youtube reboots, it's now fixed by hephappy
- Still has test kernel 23, But try out any of the newer kernels to your liking. Test 21 still gave the best ontime clock
- known bug when viewing html vids in the browser then switching to the Youtube app, the vids are choppy. Force close the browser and youtube app to fix. This is due to the codec not getting released between apps.
Bugs
[BOX="DOWNLOADS AND GAPPS"]
No mirroring or repackaging. But
patches are fine.
Paranoid Android for thunderc build 1: For more info paranoid android info
ALPHA 19E
MIrror1
GAPPS
- GAPPS TEST1. Less downloading needed, but remove what you don't want. Testing different install scripts. This one can be installed right after a rom flash. Then turn on a2sd or d2sd. Gapps with hacked market for dpi changes, includes gmail, google voice, youtube, titanium b/u free version, rootbrowser free, and amazon app store installed to data/app or sd-ext/app. Just delete what you don't want in the zip..data/app folder and flash. ~42 MB
- GAPPS TEST2. Same contents as above. Install goes like this. Install rom. Reboot to system. Turn on A2sD or D2sd if you have an sd-ext partition .Reboot to recovery and flash this Gapps This should install to sd-ext parttion..
Older Gapps with non working voice search, but includes news and weather widget. Just uninstall voice search via titanium backup and install in Google play.
Or try out quattrimus builds by tdm for ls670 phones. It should be pretty close in builds except for kernel and recent apps. http://forums.androidcentral.com/opt...s-ics.html#anb
Gapps changelogs
[/BOX]
[BOX="Install instructions"]
Install
1.Make sure you are on ZVD radio(sprint only), rooted, and custom recovery installed. Only Xionia and drew's Cannibal recoveries are tested.
2.Boot into recovery and nandroid your setup as this is alpha and may not be
a daily driver for most.
3.Now wipe Data, BOOT, SYSTEM, CACHE from recovery.
4.Flash the rom zip,
5.Flash gapps for ICS,
6.then reboot. First boot will be long.
7. If wifi doesnt turn on, turn it on and reboot. Old bug, but should be fixed now
8.Post any bugs or fixes you find here.
[/BOX]
Sources
My github
Kernels. Use built in kernels or check post 2 for updates.
Kernel sources
http://forums.androidcentral.com/lg-...c-enabled.html
Gingerkernel ICS kernel zvj
Gingerkernel ICS kernel testing
Lupohirp P500 cm9
tdm VM670 cm9 http://forums.androidcentral.com/opt...s-cm9-ics.html
Team Hydro zvh cm9 http://forums.androidcentral.com/lg-...s-its-ics.html
Rootbrowser file browser
Donations always accepted. Donut fund.
No mirroring or repackaging. But patches are fine.
Big thanks to all the testers and donaters and devs for ICS: drew, Tdm, jerryscript, Bobzhome, blarf and iho crew, mrg666,lupohirp, androidmeda, adfad666, jasonevil, cyanogenMOdLast edited by thekraven; 01-07-2013 at 12:37 AM.
Thanked by 187:+ Show/Hide list of the thanked -
5starG, aaronrw, ab304945, abandonedaltair, Alnn, Alvis, amdrohit, Amenince, AncientGeek, AndyOpie150, anthonycr, apb91781, arnold1997, arrogantbastard, austinberry8, AvantGuard, Badboytoast, BakonGuy, bbrg548, beezy, benny3, Bert019, bkttk2, blockhunsberger, bluefalcon13, bob2300, BobZhome, brgavino, bszuch216, Buddlespit, c1phr, CardcaptorRLH85, cbucz24, chcub1, chedder66, chottis, chucksaysblah, clodfelterac, cmerlyn, Compeek, Conker1r, ctgova, curtvan, Dannyman3819, darktoy, DaveSchulz, ddamienzz, deadset, deaftones, dennyc23, dobbs69, DoesItMatter, duffieldj1, duffkitty, eletendre84, Encerspay45, EnMod, ens04, epicb0dyc0unt, epidenimus, eps1lon3, erikman1983, Esp_eon, Evil_Lite, fankhanelraul, fenderman, feyerbrand, fiyah, foxliek, FreddyFredFred, FUNNEL SPIDER, rukin5197, georgetanner, Glenar, glenesis, gollum18, goofwear, Guppy, HaiTek, heathspawn, HurrrDurrrDURP, illinoissparks18, inceyet, inches0, Invincible Madness, itsrayray, jakedp7, jasamour, Jashafi, jasonevil, jaywalkerd, jf_android, jjairal, jlb0v3, jmb1317, joerivera17, johnh02, jonny5449, koeylondon, kylemaguire, lebooo, lerxst_x, lgos, Lolanerd, LoyolaGrad, Luniz2k1, makyron, mattrb, mdoorkeeper, me2151, Menthu, mikebontoft, mkfryan, mlson, mobius1484, mortalapeman, mr.longbough, mrg666, MrZackarius, Nate456, nichobrooks, Nick7, noonebutkev, notebooko, olmos.lalo, onebigjoke, optimums, orange.waters, Partof300, PatrickAkridge, payednfull, pdxguy77, pellik333, Pkt_Lnt, pluesama, poweredge99, PrimeOne1, prowlingfox, pupkus, r0gu3dev1pr, Raizo Uchiha, rand807, Rathalos420, rebel69ization, RED MAN, relentless25, res6jya6, rusty2788, RyanJKremer, Ryuk6666, S3rg, SanchezTG, Sdude1200, Seditec, sellers86, shawnpinter, Shinkenred, shnypz, shock_15, sillymeu2, sjc11221, strabo231, Stryeguy, StumDroid, taha1112, thenameisnigel, Thraeryn, TNK2, tovinhudson, traxxasBandit, troark97, twtippets, Va1ha11a, veeps15, vernotzy21, wanabee, WannaB, wintermute27, wormy987123, xplode196, XxPyromaniacXx, yodaboy18, YoshinJaa, zatioichi, Zhara, _abandonedaltair_, _alexkta
- 02-17-2012, 03:26 PM
Thread Author #2
Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband on
HOT FIXES: If stuff don't copy correctly, ie wifi drivers, try mounting system in recovery, then flash. Always flash kernels last after patches or boot.img. Try turning on wifi, then reboot. Turn off haptic feedback on the keyboard to get rid of any typing lags.
[BOX="CM9 themechooser themes"]
some cm9 themechooser mdpi themes that work with 10G +
CM9 themes by anthonycr http://forums.androidcentral.com/opt...rner-mdpi.html
CM9 themes by jasonevil [Theme] Alpha7 and Xperia S theme for CM7/CM9 *update* 6/4/12
[/BOX]
[BOX="Better battery life"]
I've been using CPU tuner and life has been pretty good as CM7
These are my settings that I use, you can adjust the pulse settings for mobile data and sync if you choose. Mine are set to check every 15 minutes and stay on for 5 minutes. Just unzip and copy the apple folder to your sdcard @ /sdcard/ch.amana.android.cputuner/configurations/ http://forums.androidcentral.com/att...1&d=1347053457
[/BOX]
[BOX=CAI ALPHA 19 patches]
- 12/2 Gallery video thumbnail fixes from hephappy and latest omx fixes from Ganster41, it should work for Alpha 19E and the Paranoid 1.6 builds. Flash in recovery Attachment 49210
- 11/20 Virgin 19E patch.... Attachment 47710
[BOX=ALPHA 18 fixes]
11/11 Virgin fix2 for alpha 18 Attachment 45736 Build.prop fixes should help with market compatibilyt.
10/30 Alpha 18C, 3rd party wifi tether mix.. reverted something that could have broke it. wifi.3rd.partyfix.alpha18C.zip
10/29 Alpha 18C only Panoramic fix. Panoramic.fix.alpha18C.zip
10/13 Virgine fix for alpha 18 updated above
10/08 VVM visual voicemail fix for sprint 9016 text messages. For those that don't use google voice. You will still need to install the sprint vvm apk. http://forums.androidcentral.com/att...m9alpha17g.zip
[/BOX]
[BOX="ALPHA 17 patches"]
10/10 VIrgin fix for alpha 10G try 3. Virgin.fix3.cm9alpha17G.zip
10/07 Virgin fix for alpha 17G only ... didn't work. Made the phone fc
10/06 Fastcharge switch for alpha 17G 9/20 Fastcharge toggle...turn on/off added to Settings/Device/Advanced for use with Alpha17F.
Behavior: Checked means USB fastcharge activated and adb functions are off. Unchecked is normal usb slow charge and adb functions like normal. http://forums.androidcentral.com/att...3&d=1348159323
9/30 Old fonts folder... should fix Japanese and Chinese characters. Wipe cache and flash the file.http://forums.androidcentral.com/att...9alpha17f-.zip
Test19 Kernel with Fastcharge via USB patch http://forums.androidcentral.com/att...5&d=1347691495
See this post for more info http://forums.androidcentral.com/lg-...ml#post2155852
Virgin fix for alpha17a-17f only builds http://forums.androidcentral.com/att...1&d=1346971919[/BOX]
[BOX=kernels] Test 21 kept battery stats and no clocklag.
- 1/16/03 test kernel 40 2.6.35.14 added bluetooth patches from androidmeda
- 1/15/03 test kernel 39 2.6.35.14 added wifi patches from androidmeda
- 11/30 test kernel 38 2.6.35.14 same commits as 37, but compiled using test 21 config. Seems to fix betterbattery stats.
- 11/30 test kernel 37 2.6.35.14 more uid stat fixes, up to date with hephappy kernel. Increased sdcard timeout
- 11/21 test kernel 36 2.6.35.14 sources. Update ashmem to msm-3.4 ..check the nk3 branch for latests commits. The best in battery life so far, still has clocklag and battery stats not accurate.
- 11/20 test kernel 35 2.6.35.14 sources. added ktimes fixes from IHO, fbuffer fixes ...
- 11/7 test 33 kernel 2.6.35.14 sources, finally replicated no clock lag with the new source.... spoke too soon.. clock lag also
- 11/6 test 32 kernel 2.6.35.14 sources, msm_battery: update the status upon resume
- 11/6 test 31 kernel 2.6.35.14 Suffers some clocklag
- 11/60 Test 30 kernel 2.6.35.14 new sources. See here for changelogs about 5 pages worth.
- 11/2 Test 26 Kernel. Old 2.6.35.7 source with test21 config +added alarm wakelock fixes
- 11/2 Test 25 Kernel. Using test 21 config with a good time keeper rebased on the 2.6.35.14 source.
- 10/31 Test 24 kernel. Trying out BobZhome's kernel source. 2.6.35.14. hk-ICS-CAI-test24--kernel.zip
- 10/15 Test 23 kernel. added alarm wakelock fixes and battery life was better, but suffers clocklag
- 10/09 Test 22 kernel. Turned on some ipv6 netfilters, hk-ICS-CAI-test22++kernel.zip
- 9/25 Test21 kernel ... USB fastcharge kernel, ksm tweaks from epinter, tweaked deadline scheduler for performance, reverted bcm4325 patch this should fix some missed alerts. So far this one had the best clocklag fixhk-ICS-CAI-test21++kernel-uncompressed.zip
- 9/20 test 20 kernel ... hk-ICS-CAI-test20++kernel.zip
- 9/... Test19 Kernel with Fastcharge via USB patch . Best sleeping kernel
- See this post for more info http://forums.androidcentral.com/lg-...ml#post2155852
[/BOX]
Template.zip for manual flashing. I recommend using 7zip to open the zip files, and notepad++ to edit files. How to flash zip your own files. I push my files via adb commands, but this should help those that can't do it. Open the template zip. And drop whatever files you want to flash. For example, say a MMS.apk goes in /system/apps, a bootanimation.zip goes in /system/media , gps.conf goes in /system/etc. SystemUI.apk goes in /system/apps, frameworks-res.apk goes into /system/frameworks .
Place whatever file you want to flash in the correct directory in the zip. Like for the build.prop, edit how you want it, then place in the /system/ folder. For apps, /system/app/
Now copy to your sdcard and flash in recovery with signature off.
1.Notepad++
2.7zip
3.template.zip
OLD STUFF:
OLD kernel links
Old ICS kernel.. hydrokernel by ddrewwalton192168 http://forums.androidcentral.com/lg-...c-enabled.html
Old ICS CM9 kernel by drewwalton192168 [KERNEL][GB/CM9] iScream Kernel v01 (ICS, baby!)
Old GingerKernel 8.1, thanks to drew for allowing use.
http://forums.androidcentral.com/lg-...bug-fixed.html
Gingerkernel repoLast edited by thekraven; 02-23-2013 at 03:41 PM.
Thanked by 39:+ Show/Hide list of the thanked -
aaronrw, Alvis, Amenince, AndyOpie150, austinberry8, Badboytoast, Beasters55, Bert019, bkttk2, bluefalcon13, Buddlespit, chcub1, chedder66, clodfelterac, cmerlyn, Conker1r, Dannyman3819, deadset, duffieldj1, inceyet, jasamour, jonny5449, koeylondon, lerxst_x, Lolanerd, MrZackarius, olmos.lalo, PatrickAkridge, PrimeOne1, Raizo Uchiha, RyanJKremer, SanchezTG, Shade808, shawnpinter, Thraeryn, TNK2, WannaB, weclee, wormy987123
- 02-17-2012, 03:40 PM #3
Make sure to flash the keypad fix, or there will be NO home key.
Great job kraven!Thanked by: - 02-17-2012, 03:43 PM
Thread Author #4
Thanked by 5: - 02-17-2012, 03:46 PM #5
- 02-17-2012, 04:08 PM #6
bad man best work as always u da man
Auto correct sucks :-) - 02-17-2012, 04:19 PM #7
- 02-17-2012, 04:23 PM #8
- 02-17-2012, 04:52 PM #9
Yeah boi! Git er done! Heh heh get it? Git?
Btw lupohirp re-uploaded his source including his kernel. Full hw acceleration is near I think. - 02-17-2012, 05:12 PM #10
nice!!
I might revert back to VD to try it out, but that seems like a lot of work. lol - 02-17-2012, 05:12 PM #11
Nice work kraven! I love that the optimus dev community is still kickin strong.
- 02-17-2012, 05:18 PM #12
kraving ice cream?
Thanked by: - 02-17-2012, 05:49 PM #13
not getting 3g or wi fi i will reflash and see what happens
- 02-17-2012, 06:05 PM #14
Installing it now.
Was a pain in the **** it revert back to VD, but i did it. - 02-17-2012, 06:11 PM #15
Can anybody report to me whether or not mic works with my gapps? I deleted some files that might be needed for that..
Just need to know whether or not I need to add it back in
- 02-17-2012, 06:13 PM #16
wi fi and data dont work please help
- 02-17-2012, 06:17 PM #17
- 02-17-2012, 06:18 PM #18Thanked by:
- 02-17-2012, 06:20 PM #19
does 3g data no work.
- 02-17-2012, 06:21 PM #20
hello i need help.
my data not working.
thats all any fix to this i cant even do android marketThanked by: - 02-17-2012, 06:22 PM #21
- 02-17-2012, 06:23 PM #22
- 02-17-2012, 06:25 PM #23
- 02-17-2012, 06:29 PM #24
A dirty flash is when you only wipe cache before flashing.
The data is still pretty iffy because this is still in alpha, but you can try turning on airplane mode and turning it off...
also, check out the Kravens cm7 thread, they talked about data problems over there.
http://forums.androidcentral.com/lg-...-only-199.html - 02-17-2012, 06:33 PM #25
im going to sit this out until its moar stable but I want to thank you for your work.
Thanked by:
Reply
