Hmmm, idk why. So do you get MMS ok with VM?for some reason no buttionswaps work on alpha 10
alpha 10 sounds amazing lol hopefully will have ics back on my phone before work tommorrow if the download link goes up i just love ics so much more than a phone lol
I know the feeling. I got the PM and suddenly there was a flurry of downloading, pushing files, wiping, flashing, etc.
Haven't tried things out with straight hk pre3. I should give that a test run, see if I notice any differences.
The test5-kernel-cam3 kernel? Or is there another I somehow missed due to being blind and . . . more blind?
Edit: Unless you mean it's built in to alpha10, in which case I am dumb and more dumb.![]()
Haha, i can only send pm's to 5 at a time.
Umm I thought I sent a mass PM. Did you not get it?
Where can I get the key fix for ics? Because it said invalid link for the last one someone give a link ?:0
Here try this one I used signapk to re sign it and it should work:
VMFix-cm9-alpha10-Zakman-signed.zip
The fact that you(thekraven) got the cam preview working AWESOME!!! is there anyway you can help me to get flashplayer 11 working on this? I MUST HAVE IT, PLEASE![]()
