What could possibly happen if I flash this on zvj
Sent from futuristic optimus s
Tested?
Also my phone still doesn't show that it's charging. None of the usually animations are animating. Nothing states that the charger is plugged in...
No, but flashing a zvd rom on zvh or zvj= no service. Go ahead and try if you want.
Will I still be able to restore backup and get service
damn has it really been this long? I just now changed the rom from your CM7 11/20 build
Though I use the camera a lot with this phone, I can deal with it. Love the new, everything, so far. Great work again Kraven.
(installed flawlessly for me even after forgetting how to do it for a few months)
Look forward to the camera fix if that ever happens
Try these tips . unplugged, Hold down the home key, volume down button and power button. Keep those down, then plug it in, and see if you get to recovery. Off line charging is still not working. But on mine, it's always charged even from the dead.
2nd, is to connect to a computer and use adb commands. This depends on how far along in the boot process you get.
adb remount
adb reboot recovery
or
adb shell
reboot recovery
The zvj based kernels have better drivers for charging. They use a more universal google code than LG specific now.
^^ maybe try doing a reinstall of everything? (again). I cleared cache, then formatted boot, cache, system and data. installed from zip the A9 build and gapps.
Everything but the camera works great for me after using for a day. Accurate " time on battery" stats, charging icon and notifications work, 3G data and wifi work, mms with stock app, phone calls, picture messaging and youtube all work flawlessly. power button works after the hotfix.
Must just be my luck![]()
if you install hydro kernel, the camera works too. the ONLY thing that doesnt work is BT audio and camera previews/camcorder.
I randomly stopped getting text's for two days and i just flashed Drews new ICS kernal and all of the sudden I got all the texts form the past two days? lol
Where the kernal download link. ??I randomly stopped getting text's for two days and i just flashed Drews new ICS kernal and all of the sudden I got all the texts form the past two days? lol
