[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband Alp
Happened to me. After making changes to the notification settings, reboot the system.
You will see the changes. I can see and toggle settings after reboot.
Yes, just got there. I hate to think how many reboots I have done today on the alpha test merry-gp-round. :)
Can you change the button order? That eludes me......
:( Data isn't working again. Rebooting again now. Will have to wait for it to settle i guess.
and yeah, i changed the widget button order and could see the change right away though :D
EDIT: hehe, data working again. This is making me go crazy and yet love to have ICS on our phones. God save us from these guys.
Much respect to you Kraven.
OK. Seriously someone please turn on your Wi-Fi and when it connects go to a quiet place and listen to your phone. Mine is popping like crazy but not with Wi-Fi off. Clicking really fast. I'm running alpha 2 and iscream kernel. 3g is not doing this.
Sent from my LG-LS670 using Tapatalk
Can I remove LatinIME.apk if I'm using Swype as keyboard or is it needed for Swype work?
EDIT: I removed email, email exchange, youtube, camera, trebuchet, live wallpaper and freed about 12MB. If I dont need the above, thats 10 more MB there.
tried the *#*#4636#*#* thing to no avail. 3G symbol appears but internet did not work. However, it did work before I did this trick for about 2 minutes after I let my phone sit for about 10 minutes after i flashed, and then never again.
Before the trick, Wi-Fi was also wonky. it passed the ping test to my router, but failed to ping hostname. After I did the trick it works fine.
On another note, is anyone else experiencing 16-bit color? This has been happening to me in alpha 1, and alpha 2 with drew's kernel.
Gallery is not working for me on aplha2.
just sits at a black screen
I clean flashed, I flashed the debug.format, ROM, kernel, then gapps.
right when it started up, I restarted it. then data worked perfectly...
Btw the newest Swype beta is way better than the version we first saw on the stock ROM. Try it out
Tapatalk BIATCH!!!
I actually think that might work on mine. Everyone has to think if upgrading from CM7 (port by the kraven) to CM9 (also a port by the kraven), that is a big step and I actually had an extra APN added to CM9 that was apart of CM7... so I think I might try regular flashing because all I am doing is dirty flashing CM9.
Its odd... i had NO apns :/ i had to make some then data works(only at 1x though)
yea. ill do it again though
Had that too, with SlideIT. Gave up, lots of alpha bugs. I still cannot get most system settings to stick. Power widgets in notification bar for example. I can select what to display, but cannot change order and they do not display.
its gone away now....
completely unrelated to the the topic, but it says you have a kindle. Is it worth buying and rooting, and have you tried cm9 on it?
sent you a PM on the OT reply.
CM9 Alpha 1 build for Sprint optimus S
"COLD AS ICE"
ZVD only
ALPHA 1 build
Code:
Latest cm9 sync
Sprint in the notification dropdown
Thanks to tdm, Bobzhome, and lupohirp git repos,drewwalton192168 for
gingerkernel, LeslieAnn for the IHO server, blarf and Iho crew.
ALPHA 2 build
Code:
Lots of room made in this build
~80 MB and you can delete Trebuchet.apk and save about 7 MB more if you like the Apex launcher included.
Youtube kinda works now, getting closer.
You will still need to flash Drew's new ICS kernel.  This still has the 8.1 GK one.
Latest CM9 sync.
Sync with Beta 4 of P500 changes.
Using the IHO sprint apns-conf.xml.   So test mms.
LatinIME.apk is large ~10 MB, so look on the market for a mdpi on if you need room.
Has the home key fixed
Handset mic should be working with apps that call for it like groove ip and voice dial.
PEOPLE! LISTEN! I FIXED DATA ON ALPHA2.
UPDATED TO FIX ALPHA4 BUILD..... AGAIN, THIS FIX/PATCH NOW WORKS WITH ALPHA4... THANKS.
HOW THIS DATA FIX WORKS:
GPRS provide Internet (in this case, 3G or 1X) services to your phone. Before my fix, GSM and GPRS service wouldn't stay connected to the phone, leaving Internet services a no go. This fix, along with the help of APN's to connect, keeps the GSM service connected to the networks worldwide. GSM service now is always connected, providing your phone the capability to send and receive data. When your phone makes a request to access the internet, GSM service recognizes the request and attempts to connect through GPRS service to send and receive the data. Since GSM service is providing the network and your phone with Network Based Locations and is always connected, when your phone makes the request to send or receive data, GPRS service automatically connects.
I am not the smartest cat when it comes to the roots of how the network works, but I tried my best to clearly let you understand how this fix works.
By the way, I have noticed that the GPRS service kicks in when the phone sends a request or when you unlock the screen. GPRS DOES connect while the lockscreen is enabled, but I have noticed that GPRS kicks in when you unlock the screen.
PLEASE NOTE:
The GPRS service DOES connect if you follow these steps, but it may be a little behind connecting. For example, if you are trying to browse the web, it may say that it can not connect before GPRS connects. GPRS may be a little behind connecting while you are trying to access 3G service.
HOW TO APPLY THIS FIX:
To fix the 3G data on Alpha2, shut down the phone first.
Reboot into CWM or Xionia recovery... Then nandroid backup as usual... then, CLEAR DATA, CACHE, DELVIK CACHE, BOOT, SYSTEM, and if you have it, SD-EXT. Then, wipe cache AGAIN.
Once you have wiped, flash these things IN ORDER... ROM, Kernal, G'apps. YES. IN THAT ORDER.
Once you have done that, FLASH THE ROM AGAIN. YES, AGAIN.
After that, wipe cache and delvik cache once more.
Reboot... then reboot again. Go through the sign in first time boot thing. Skip syncing at first... Then go to settings > more (under wifi and bluetooth) and toggle airplane mode TWICE. Then, go to mobile data and toggle twice.
IF YOUR 3G ICON IS NOT SHOWING UP ALL OF THE TIME:
The 3G icon appears when GPRS service is connected. Just because the 3G icon is not showing up doesn't mean that you don't have Internet access. I have noticed on my phone that the 3G icon is a little slow appearing when GPRS is connected.
To be sure that the GSM service is always enabled and the data is sticking even though the data icon is not showing, type *#*#4636#*#* in the dialer... go to phone > ping test. You will want to see "pass" on all three things. Also, you will always want to see GSM - connected in that testing screen. I see that it is best to preform random tests on it only when the 3G icon is not showing. Test your GSM and data connections at least once a week.
IF THIS DATA (3G DATA) FIX HASN'T WORKED FOR YOU:
If you see "Fail" or "Unknown" on the second thing in the list while your icon is not showing up, try repeating these steps since the "booting and sign in" part or try reflashing the ROM. Make sure your APN's are okay by going to voice dialer and saying "open A-P-N's" or "open A"... if you see one or three APN's or they are not right, go look at thekraven's tip for 3G connecting.
WHEN YOU REBOOT THE PHONE, YOU WILL NEED TO PREFORM MORE STEPS ...
If you reboot the phone and the data starts acting crazy, repeat the toggling airplane mode/mobile data part.
If you STILL can't get data to stick... Reboot into recovery and clear Dalvik Cache and Cache. After that, it should stick. If not, check your APN's... If all of the above STILL won't let data stick, repeat this whole thing.. Thanks
If you have apps that need to be reinstalled that have been backed up using Titanium, fine. Reinstall, but do not restore sys data as it screwed me up.
Please show your apprication by clicking that white thanks button for me! :-) Thanks for applying my fix!! :-)
Thanks guys!
To be sure that the data is sticking even though the data icon is not showing, type *#*#4636#*#* in the dialer... go to phone > ping test. You will want to see "pass".
If you reboot the phone and the data starts acting crazy, repeat the steps since the booting up part..
Thanks guys!
sweet, testing that now
Anyone having trouble with alpha2's camera "can not connect to camera."?
The camera will need more work.
Anyone try the gallery from alpha 1?
this is what i get when i open gallery in alpha 2
I click on albums and it will bring down a list. that lets me click and change it to locations, etc..
And i can hit the menu button and brings up the menu. if i click the settings it freezes then force closes
Yes, you could view images on the SD card. Never thought to pull that one and push to alpha 2. Camera and albums are not high on my priority.
Takyi Benedict
