[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
I'm amazed at how useable this rom is already and only deal breaker that may get on my nerves is spontaneous soft reboots. Even without overclock using the InteractiveX governor.
The other issues are minor and can be overlooked. Like why am I able to use the dropdown notification bar while the screen is locked? Google Voice doesn't integrate but does work. The battery history and data usage does not work yet. No incognito in the browser.
Like I said though, many of these issues are easy to overlook and aren't deal breakers.
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 4/5 ZVD basesband Alph
I believe the notification bar on the lock screen is an ICS feature. :)
were you using the the stock text message app to receive the pictures. And can you send you self a an mms because I can't send my self an Man. I'll see if I can have some one send me an mms
I actually use gosms pro
wow data and wifi working perfectly for me. hello daily driver!
FYI. Incognito does exist however its in a different location than in gingerbread.
Open browser.
Tap the Tab icon next to the address bar.
Press the Menu button and select New incognito tab.
Sent from Tapatalk
@WannaB Thank you , ill re install gosms pro and give it a shot,
and for others trying to over clock i have had the same problem, going over 740 or so my phone would keep restarting after booting up. i was able to change the setting really fast back to normal, before rebooting, that way i did not have to do a nand restore . hope that helps some
Thanks for the Incognito tip. I couldn't find it before :D
As for the lock screen notification drop down I guess it doesn't effect me much since it does get disabled when you use a pattern unlock. So I guess its not insecure and I haven't had a pocket accident yet so...
The soft reboots are weird. Not much rhyme or reason I can see yet. It seems to like to happen at bad times for me such as snoozing my alarm.
Just another tip, if you break something in the performance screen (overclocking, memory settings, etc) you can just wipe system and reflash without losing data, at least in every instance I've tried it. Should probably do a backup before you mess around with it just in case, but I've yet to lose anything with experimenting.
Yeah go sms pro I can send and
Receive mms :) thank you ..
Also I never had soft reboots . Only happens when over clocked to high.
Your welcome :) I use this as a daily driver. I could care less about a camera ;)
-About my email issue: the problem happens when scrolling. As soon as I try to scroll down in the message, the actual body of the message disappears. Gmail app works fine, though.
-BT is in fact still dead. It connects, but no audio.
-Another odd issue i've found: When the phone is on silent/vibrate, and you do anything that, when not silent, would give an audible touch tone (the little 'tick' sound), you can hear a bit of white noise coming through the phone speaker, even though no sound is played. This faint white noise happens every time a touch sound would normally play, and lasts for about 3 seconds. I turned off the touch sounds in the sound preferences to avoid this. I'm not sure if this also happens when getting notifications or when other tones would normally be played.
-Sort of unimportant in the grand scheme of things, but if anyone is familiar with the app TinyShark, it will not stream on this ROM. It will connect, but it will not actually play music. It worked fine on 2.3 ROMs that i've tried it with.
I've noticed that email scrolling issue in gmail sometimes. Still can't pin the issue down...
i have noticed the same issue. The problem is fixed when you uninstall any updates.
Sorry guys but it's not as simple as installing the app from alpha 8. The problem is in the Rom with the libs and drivers. If it were not we could just download an app from the market and fix the camera.
Sorry I was not thinking (under caffeinated). Forgot it was hardware linked.
from LG-LS670 w thekraven ICS/CM9 ROM & Tapatalk
Does anyone know the sprint data number it either with --> # or --> *.... PLEASE. !!!
My only complanits are the Gmail messages (fixed with a wipe cache?) No battery stats and no camera.
Are you referring to the screen turning blank when you attempt to scroll down? Simply uninstall the newest gmail version and prevent it from updating. There is something in the new update that cause it to mess up.
I don't mind not having the battery stats, but for me, in addition to not having the camera, there are occasional lockups and reboots, and the other thing that worries me is the clock drift. I use my phone as my alarm clock for school every morning and I'm paranoid that it might not go off at the right time as a result of time shifts :P Yes, I'm using ClockSync, but I'm still worried...
Bry
