[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 4/5 ZVD basesband Alph
And if you have the "kill app back button" turned on, it's known to mess with the clock sync on the p500 phones.
Well, I don't even know where to find that setting, so I probably don't have it turned on...lol. Thanks kraven
Disappearing text is a known issue. Delete GMail updates or integrate them into the ROM with TiBu, answered a number of times already.
Seeing lots of reports from newbies to the thread about known issues. Maybe you should read the previous posts if you want to be alpha testers?????
No, integrating the updates doesn't help :(
There seems to be NO mic input on keyboard for texting, looked in alot of settings. The mic is on google play and the main searchbar.:(
Maybe i'm just not doing it right. What are the steps?
What I did was update Gmail, open TiBu, menu -> batch -> scroll down to integrate updated system apps into ROM, click yes, select gmail, click go. It tells me the operation has completed successfully, I reboot, and I still have a blank screen.
any reason why the market wouldn't show up my purchased apps?
edit: cleared data and that fixed it......silly me lol
OK, testing alpha 10 and Gmail issues non existent when app was installed. Also, drews hydrokernel REALLY made the difference. Tested with iscream kernel and BAM, hydrokernel takes the cake. CAMERA FREAKING WORKS.....OMG OMG OMG! Will test more later and post any bugs, but come on, give it up for thekraven!!! Wooot Wooot
Also going to test kernel provided by thekraven once I regain some composure....
maybe need an actual uninstallation, then re install? was that a word
I posted a newer 4/29 Gapps in the OP. I'm not too sure off what was updated, but I noticed that it downloads the Market/PLay now, and GMail is not included.
The play store being there helps me out simply because Google will back up my apps now instead of asking for me to accept new terms and then install nothing
Sent from my LS670 using Tapatalk 2
Can't find the download link for alpha 10 its not in op I can't see it please help
Sent from futuristic optimus s
wahhhhhhh do want
Camera preview rocks! I wish I could find button remapper on the market. Otherwise things are awesome!
What are the differences between HydroKernel ICS and the included kernel / any of thekraven's testing kernels?
Kravens test has better UI scrolling and stuff like that
@kraven when are you posting alpha 10 to the public?
Well hydrokernel made my camera run real smooth as well as overall performance. And not overclocked at all phone is VERY responsive. About to make a nandroid and test thekravens kernel out. But so far, EPIC.
annahernandez51
