[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband on
Make sure you are on the right baseband. Also if you dirty flashed, that could be a problem...
on zvd and i got wi fi working.
data doesnt work see my older thread.
please help im using wi fi but no data is there a fix to this and whats a dirty flash all i did was flash from recovery zefies
A dirty flash is when you only wipe cache before flashing.
The data is still pretty iffy because this is still in alpha, but you can try turning on airplane mode and turning it off...
also, check out the Kravens cm7 thread, they talked about data problems over there.
http://forums.androidcentral.com/lg...ptimus-s-thekraven-2-7-2012-zvd-only-199.html
im going to sit this out until its moar stable but I want to thank you for your work.
i wiped everything and im coming from the kravens cm7 and had no problems
working after airplane mode thanks guys
Sometimes after coming off of Wifi or a reboot, my 3G doesn't connect but shows that it's on...I have to go to settings and turn Data off and back on and it connects...
do old titanium backups not work????
I had the same prob.
Turning data off then on fixed it to.
As long as you are using the current Titanium Backup it should work. I've restored several things (but there's not a lot of app room so you might not be able to restore everything.)
data worksperfectly for me :D
Just so everyone knows, I'm nearly finished porting the newer KGSL driver and the genlock driver to GingerKernel. I believe these are the final pieces of the puzzle for full H/W Acceleration. Stay tuned...
It is working good for me to.
Right now its looking like it turns 3g off when you are not using it.
casue i look and the 3g is gone until i start to use something to use data then 3g pops back up.
So you couldn't resist testing it out could you? :D
small bug.
When typing on facebook, google+, and others, spell check says all my words are mispelled
does Bluetooth work for anyone else because mine doesn't and just wanna make sure
so to clarify, the mic fix also fixes the home button issue?
lordnico86
