[PATCH] Patch for BobZhome's CM10 (updated: 11/4/2012)
r0gu3dev1pr
92
15
Re: [PATCH] Patch for BobZhome's CM10 (updated: 9/17/2012)
Flashed fine, though initial boot took forever....
But so far for me the ROM has no voice/data network access, and every app that tries to use the microphone seems to immediately crash (not just voice search, recorder apps etc. have this problem as well).
What baseband are you, zvd or zvj?
Sent from my LG-LS670 using Android Central Forums
blar0
I would assume that issues with the rom would be better served posted in the bobzhome cm10 thread. All rogue is trying to do is get rid of the VM branding and make the keys work properly.
Fair enough, though I posted here largely to report success with the rom/zvj patch/rogue's patch stack where others were meeting failure following the same procedures.
zvj
r0gu3dev1pr
92
15
zvj
Bobz's CM10 is developed for zvd, however thanks to nitestalkr's patch you can now flash any rom on any baseband. I have attached an earlier version of the patch which doesn't have the a2sd script. Since you already installed the ROM, flash the zvd to zvj patch then flash my patch again.
Disregard.
  • ZVD to ZVJ patch-Optimus S-07312012.zip
memsman
142
19
r0gu3dev1pr, are there any tricks to make the ROM a little faster without significantly reducing battery life?
Thraeryn
DEVASTATOR
Mar 19, 2011
256
33
Show of hands: for those having problems with the ROM and update patch, which baseband are you on?
I'm on ZVD. I think a fair number of us who are experiencing more serious issues are on ZVD, which means we are not flashing the ZVD->ZVJ patch in our install process. Don't want to send r0gu3 on a wild goose chase, though, so pipe up and let's get some crowd data.
hallwal
I have ZVD, and have the same problem. I can install the rom and gapps, and it seems to work fine, but if I install the patch (to get the phone back to Sprint branding and fix the mixed up buttons), my phone hangs shortly after booting, and I eventually have to yank the battery.
Are the above posts suggesting we try patching our baseband to ZVJ, and then using Bobz's ZVD to ZVJ patch, and THEN install the branding fix patch?
Thraeryn
DEVASTATOR
Mar 19, 2011
256
33
My thought was more along the lines of seeking something in the ZVD->ZVJ patch that might somehow be effecting one last, important change. If people on ZVJ are having an awful time of it, though, then that would be a waste of time.
lerxst_x
Active member
Dec 6, 2010
28
I'm on zvd, and have had no problems other than the long initial boot.
r0gu3dev1pr
92
15
Thanks for initiating this.
I am on zvj. Only had initial long boot building dalvik.
Thraeryn
DEVASTATOR
Mar 19, 2011
256
33
Well, that helps indicate that maybe it's not due to a magical line of code in the ZVD->ZVJ fix. Still interested in hearing other responses!
TribalZR
11
I'm on ZVD and have been having problems. It's just a hunch, but could it be something with models? Like did they change something during the productions of the Optimus S? I think I bought mine sometime around november 2011.
Buddlespit
Wannabe kewl
Jan 27, 2011
671
119
I'm on zvd and like noted before, I just had a god-awful long initial boot. Well, and a problem with the mic/voice.
I'm also on the "new screen" model.
lerxst_x
Active member
Dec 6, 2010
28
Fwiw, I got mine December 2010.
Thraeryn
DEVASTATOR
Mar 19, 2011
256
33
Steps:
  • COT Pre-Flash Wipe
  • COT Factory Reset
  • format /boot
  • format /sd-ext
  • flash BobZ 09152012 ROM
  • flash BobZ gapps
  • flash LS670 patch
  • boot Android
Results:
  • screen freeze 3 minutes into boot
Steps:
  • battery pull
  • boot Android
Results:
  • screen freeze 30 seconds into boot
There HAS to be some sort of combo that works. Going to try something else and hope that another person posts so I don't double-post with the next attempt. ;)
Steps:
  • Factory Reset
  • Pre-Flash Wipe
  • format /boot
  • format /sd-ext
  • flash ROM
  • flash gapps
  • boot Android
  • do NOT complete Google sign-in
  • pull battery, reboot recovery
  • flash patch
  • boot Android
Results:
  • initial boot took 3 minutes
  • post-patch boot froze after 30 seconds
Weird.
Steps:
  • Pre-Wipe Flash
  • Factory Reset
  • format /boot
  • format /sd-ext
  • flash ROM
  • flash patch
  • flash gapps
  • boot Android
Results:
  • initial boot took 4 minutes
  • Google sign-in completed successfully
  • Home & Menu keys correct
  • lockscreen lists "Sprint" as provider
Everything seems good after this install. Going to restore some apps, make sure they end up on my /sd-ext and that other things work, and get back to you.
r0gu3dev1pr
92
15
Steps:
  • COT Factory Reset
  • format /boot
  • format /sd-ext
  • flash BobZ gapps
  • flash LS670 patch
  • boot Android
Results:
Steps:
  • battery pull
  • boot Android
Results:
Steps:
  • Factory Reset
  • Pre-Flash Wipe
  • format /boot
  • format /sd-ext
  • flash ROM
  • flash gapps
  • boot Android
  • flash patch
  • boot Android
Results:
Weird.
Steps:
  • Pre-Wipe Flash
  • Factory Reset
  • format /boot
  • format /sd-ext
  • flash ROM
  • flash patch
  • flash gapps
  • boot Android
Results:
@Thraeryn excellent work figuring this out. Kudos..
What decides the size of the system partition? Can the developer decide, or is it pre-determined by the phone manufacturer? Seems like for some the system gets full after flashing the ROM and gapps and fubars on the patch. Is everyone flashing the bobz's small gapps or something else. Also when you flashed the gapps last, did you notice any apps missing when once system got full it quit writing.
Thraeryn
DEVASTATOR
Mar 19, 2011
256
33
I have no idea on a lot of that; I'm little more than a knowledgeable end-user. Just tried different methods in the hopes that one would work. I flashed bobz's small gapps each time, successful and not. Uh, didn't notice any missing apps once /system got full on my successful flash since, apparently, /system didn't fill.
TribalZR
11
@Thraeryn cool beans, ill try your successful steps and see if I get the same result.when I get home later */me crosses fingers*
Thraeryn
DEVASTATOR
Mar 19, 2011
256
33
Restored most of my apps with TiBu, and they seem to be on /sd-ext for the most part; still have 82.5 MB free Internal, and have used .33 GB on /sd-ext. Operation seems to be fairly smooth. The stuff listed on BobZ's thread as not working doesn't work - surprise, surprise. ;) Going to run this tonight and tomorrow, see what additional thoughts I have. The patch, for all intents and purposes, looks like it worked A-OK this time.
hallwal
Steps:
  • Pre-Wipe Flash
  • Factory Reset
  • format /boot
  • format /sd-ext
  • flash ROM
  • flash patch
  • flash gapps
  • boot Android
Results:
Thanks!! This worked for me!! :D
karim174
