[PATCH] Patch for BobZhome's CM10 (updated: 11/4/2012)
Shinkenred
322
19
18
Okay...I've been having some rather odd problems with CM10 lately. Could I just dirty flash this, or should I wipe the phone and install it fresh?
Sent from my Purple LG-LS670 running CM10...for now.
scottyrick
22
3
This is now my daily driver CM10 for LG Optimus S, thanks to the developers here. The post 141 ROM, combined with post 1 gapps and patches, are all that was needed. If you need corporate email, just copy email.apk and exchange2.apk from the bobz's ROM into your system/app directory, and reboot.
Thanks for providing such a stable and well thought out firmware.
Shinkenred
322
19
18
Clean flash it
Sent from my LG-LS670 using Android Central Forums
Okay...gonna try that. Let's see what happens...
...and it looks like we're in business!! You are a genius-level lifesaver!!! (As in you saved the life of my Optimus S, lol...)
androidwalde
I'm a noob and I was wondering if anyone has experienced no incoming calls when installing this?
Update: It was a Sprint issue, called support and they did a reset on their side for my number.
thewraith420
1,987
223
63
I
Do you think I could just install this with RM or should I use a pc
Sent from my LS670 using Android Central Forums
Umm I wouldn't use rom manager for anything on an optimus s/v it doesn't have a supported recovery for your phone. Only the optimus c and it's not the same and will not work correctly
Edit: also you don't need a computer. just flash it from a custom recovery. If you need help installing one please refer to the stickies at the top of this forum.
