[PATCH] Patch for BobZhome's CM10 (updated: 11/4/2012)
biggjoe
181
4
Just curious,
As far as Google Play store and other 'GApps' not properly flashing/installing, has anyone tried to do a backup/restore with Titanium Backup by any chance? Since there aren't many CM10 ROMs to come from, perhaps a compatible ICS CM9 ROM, Titanium Backup and then restore after successfully booting into BOBZ's CM10?
Just thinking out loud...
BJ.
eletendre84
#sarcasm
Jul 15, 2011
386
80
Ive created a cm10 zip that is flash able on the S and has plenty of room in /system. Lmk if anyone needs it and I'll give them a link. I won't post it publicly, as I don't have bobs permission.
eletendre84
#sarcasm
Jul 15, 2011
386
80
Its the cm10 from Bob, minus email.apk, Apollo.apk, and calculator.apk (all can be installed later). A smaller Latin ime.apk, the fonts folder from cold as ice and the framework-res.Apk and keylayout from rogues patch. Flashes 122 megs to / system, plenty of room for gapps
biggjoe
181
4
Aaah ok...so it's a modified .zip of BOBZ's ROM. After flashing that, do I flash the smaller GApps? Can you please send me the link?
Thanks!
BJ
Sent from my LG-LS670 using Tapatalk 2
r0gu3dev1pr
92
15
Rogue, MMS doesn't seem to work using your patch. Any suggestions?
Did you flash your zip with the changes? I noticed that you did not include the build.prop file whicj includes sprint's network numbers. If that's the case, give it a try.
Sent from my LS670 using Android Central Forums
muerte33
eletendre84
#sarcasm
Jul 15, 2011
386
80
I've redone the .zip with the build.prop changes. Its down to 83 mb. Just waiting on a yes/no from Bob to post it.
Sent from my LG-LS670 using Android Central Forums
r0gu3dev1pr
92
15
can someone tell me how to change the hardware buttons back to normal
This patch includes the fix, so if you flashed it and its still not working then your system is possibly full. Try deleting some ringtones or something then flash this patch again.
Hamelin
10
Is there any public fix for gapps not installing correctly yet? I'd really like to use this but without the market I can't do anything. I thought having a sdext partition would help but it is not.
Edit: I got everything working but MMS myself, I think I need to edit the build.prop. Is it just a matter of editing a file or is it more complicated than that?
findmorypoker
LS670ZVD Create 512MB (32MB swap) sd-ext partition. Flashed ROM, Flashed Smaller gapps, Flashed patch. everything works nicely except Play store not installed? What I am missing?
rickness54
