On my Honor device, you go into Settings, scroll down and tap Advanced Settings, scroll down to Backup and Reset, and then tap Factory Data Reset.
There is no advanced settings on this phone. Not that I can find.
Take a look at this: https://youtu.be/KyPbU9vQ0uoThere is no advanced settings on this phone. Not that I can find.
You'll need to download Gboard from the Play Store. Once downloaded, just open it like any other app and it will walk you through the process of setting it up.Ok I've done the factory data reset & started it as a new device but how do I change to the Google keyboard?
Good. Glad you got it set up like you want it.Don't worry I've found it. Got the phone all set up for how I had it before but can't find the turn off vibrations from twitter notifications. Also can't find the always on display too.
That's great. You're welcome. Glad you got it working.Thank you now I have my AOD plus I read that article too. Thank you was useful.
I never used Huawei's cloud service, so I'm not sure what's going on. You might want to try logging in to your account from your PC to see if it gives you any info. You might need to add your phone to your account again since you reset it, but that's probably not the issue.For some reason when I got to settings then choose my Huawei ID I can't get cloud to connect. Every time I try it says failed to connect to server. Had it connected before I factory reset the phone. Any ideas how to get it connected?
How is your Facebook app? I'm having scrolling lag and stutters a lot.
That's great news. I'm glad you got it working the way you want.It's been a week since I factory reset this phone there has been no restarts at all. Still adding a few apps back everyday & nearly complete with all my apps only a few left to download. Maybe I did have a buggy set up from my old phone.
