Notefan161
- Jan 9, 2019
- 810
- 11
- 18
I can't see anyone dropping a ton of money on the Note 20 Ultra, only to gimp performance so it can match the battery performance of the S20 Ultra. Why buy it at all then? If the screen is as efficient as they are claiming it should be good to go. It only a 10 percent drop in capacity anyway. If you can't get through the day with 4500mAh, you won't with 5000mAh either.
LTPO should help with battery life though so 4500 should be enough
