Boxwave baby!Mine is on the way. I always use them and they last the life of the device (I never keep a phone more than a year)
Then that's not the life of the device.
I have a clarivue and it's great.
So it has the cut out for the camera? Does it the cut out for the sensors as well?
Sin1134: I love the innocase. I got lucky and found the one with the holster at a best buy near me. Do the seidio cases have the cutouts for the front camera and/or sensors?
those zagg shields seem to messy and complicated to me
how hard is the boxwave to put on take off ? Also i take it that it will not leave a residue?
I agree. I bought StealthGuard brand screen protectors and the instructions said to use water. I decided not to, because of the horror stories I've heard, and because the protectors were sticky enough to not really need water. I got the second one on w/out bubbles, but it still looks crappy and doesn't feel good on my finger. Part of the problem is that tho there are no air bubbles, there's still air trapped, trapped in such a fine, well-distributed way that it doesn't clump into bubbles. But it's there nevertheless, and the visual result is that it gives the screen an uneven distribution of light transparency. That is, the parts with more air appear lighter, more gray, while the parts with less air appear darker, more black (which is good).
i love the zagg invisibleshield had on the pre and now on the evo. I had other but zagg are the clearest and they never scratch. And a lifetime replace. Which I used like 4time with the pre.
