incarceration
- Apr 5, 2011
- 81
- 3
- 0
Re: Drew's CyanogenMod Hacking thread (current build: 07/27/2011)
Are you running any custom ROMs?
What problem are you asking for help on? I'm sort of confused. At first I thought you were having the same issue I was with getting the Swype Beta to work, but then I saw later in your post (an unedited post at that?) that you figured it out. Are you reporting now that you're getting those errors now only?
If you're running a custom ROM I would suggest reflashing the ROM and\or uninstalling the apps you are using when those errors occur. One thing I've noticed is some apps don't properly transfer from a backup to another ROM so redownload and reinstall it and then it should quit the errors (if it's related to that)
