ARCHIVED: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2011)
Status
Not open for further replies.
This is great! I'll be flashing tomorrow. I was using ath3nos time but since he will stop updating soon I'm moving here. I'm out of town with no computer access so I'm going to dl over night and put it into action tomorrow. Thanks drew!
Sent from my ath3nos CM7/ XioniaRedux lg-ls670 using Tapatalk.
Re: Drew's CyanogenMod Hacking thread (current build: 08/01/2011)
I can confirm working bluetooth headset for calls. Not sure about PRL or Profile. I tried them both but no change on the PRL. Even after a reboot.
THANKS DREW. Bluetooth was the only thing I was missing and YOU FIXED IT.
What is your current PRL version? Go to Settings->About phone->Status
After updating prl or profile, mine just calls Sprint, and then hangs up and goes to the lock screen.
PRL: 1115
Awesome Updates. I was looking forward to the Bluetooth fix. The PRL don't help me much because this phone is Flashed to use Cricket but I'm sure lots of other people will get use out of it.
Thanks again dude for your work on this rom. Ill pass some coin your way in the coming weeks when I get to a terminal or home (I'm a OTR Truck Driver) I'm not crazy about passing CC info over a Truck stop internet hotspot lol.
I'm carious if I do this update on my v, lets find out...
PRL: 1115
PRL 1115 is the latest update for your particular account type. So is 60680. Having either of these PRL updates at this time will cause the PRL/Profile update mechanism to behave strangely.
Not recommended, but go for it. Don't be surprised if things behave strangely.
Ha, it worked and I didn't even know it!
How did you find out that 1115 is the latest update for my device?
Your a remarkable guy Drew....
1 more thing... Do we need to Re-Flash the Kernel also?
Thx
Re: Drew's CyanogenMod Hacking thread (current build: 07/27/2011)
Are you running any custom ROMs?
What problem are you asking for help on? I'm sort of confused. At first I thought you were having the same issue I was with getting the Swype Beta to work, but then I saw later in your post (an unedited post at that?) that you figured it out. Are you reporting now that you're getting those errors now only?
If you're running a custom ROM I would suggest reflashing the ROM and\or uninstalling the apps you are using when those errors occur. One thing I've noticed is some apps don't properly transfer from a backup to another ROM so redownload and reinstall it and then it should quit the errors (if it's related to that)
Sorry my post was confusing, I'm new to Android, I'll try to clarify:
I haven't installed any backup apps, all apps were installed fresh.
I'm running a script on Drew's ROM to make it compatible with my Optimus V, I guess you could consider it a custom ROM? I flash Drew's ROM, gapps then Sprint-to-OV_ath3nos_signed.zip .
I have not found a way to install Swype Beta but I found a workaround for it by reinstalling the stock Swype which came with the phone.
The problems I was asking for help on were:
a) You said, " ... and then stumbled upon where the setting was to switch it from "Android Keyboard" to "Swype" cause it's been removed from the "Language and Keyboard" menu. "
Where did you find the setting to switch keyboards? Both Swype and Android keyboards are missing check boxes for me under the Language and Keyboard menu.
b) Does anyone have trouble using Thick Buttons keyboard? (This is the only keyboard I installed that actually does have a check box but the keyboard itself doesn't work properly)
c) Is anyone getting "The application Settings (process com.android.settings) has stopped unexpectedly." and having to force close? I get this from a few different places in the settings menu such as trying to change the screen brightness
If I'm the only one experiencing these problems I can assume that Sprint-to-OV_ath3nos script is responsible and seek further help in the [ROM-ish] OV Port of ath3nos's Unofficial CM7 (Gingerbread) thread.
Thanks-
Yeah I like experimenting, I already have the 60680 prl so probably wont mess with it, unless I get really bored and feel like doing something stupid... I will let you know how it turns out
Ok thanks but i have notice that when you go to Wifi>Teather and Portal HotSpot and you turn it on you get ( The application settings process.com.android.settings has stoped unexpectedly please try again . and it wont work anymore .
I have prl 60679. I called sprint to flag for an update and was told they no longer flag for prl updates. She told me to dial *18 on the phone and that would flag it. After a reboot I am still at 60679.
And it's turned on and you can't get to settings or turn it off.
A reboot will turn it off.
Yucky, this might be an issue with the IHO repository. I didn't change anything in the Wifi tether code.
[WARN]Unstable Build!
The 08/01/2011 build (Build ID DREW-003) is HIGHLY unstable. Things may not work correctly or even at all (specifically PRL/Profile updates and Wifi Tethering). This was mainly caused by a rushed release and not taking enough time to properly test EVERYTHING, including things that I understandably assumed still worked. I apologize for any inconvenience.
A more stable build (Build ID DREW-002) can be downloaded from the front page of this thread. In the near future there will be two build types, stable and unstable. Again, I apologize for any inconvenience.[/WARN]
Status
spade20
