ARCHIVED: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2011)
Status
Not open for further replies.
I agree, much credit to both of you for getting this to where it is!
Sent from my LG-LS670 using Tapatalk
Re: Drew's CyanogenMod Hacking thread (current build: 08/01/2011)
I wasn't necessarily saying you caused the wifi tether issues. It certainly could be a pure CM issue. I'll do some digging around with that.
I know. That's just a statement of fact. That said, something may have been out of sync with the rest of the CM repos. I can't duplicate the problem with my home WiFi setup (WRT-600n w/ DD-WRT), but the phone has a really hard time maintaining a 54mbps connection (might have to turn down the power on the WAP).
People are reporting the same problems with the past few BACKside builds so I'm assuming it's not a kernel issue (unless we're both using the same version of the BCM4325 driver and the same binary blob).
The funny thing about that is I caused the wifi tether crashes due to incorrectly removing the BLUETOOTH tether menu. How about that? Stable build is uploading, will release when finished.
lol i JUST downloaded the 002 build and promptly got an error when trying to verify the update. Now i come back and see that the stable is currently uploading so i will stick with my current rom for a few min and kick back for this to be uploaded :D thanks for all the hard work
How do you turn off the vibration when you make a call when I accidently go to adjust the phone it vibrates I tryed looking into settings seemed to can't find it .
I am using drews 7/27 cm7
Yeah there are some interesting interdependencies. I'll recommend resyncing the repos and rebuilding just in case there was something out of sync. Jerry found a few CM bug reports regarding maintaining a stable WPA2 connection. But... I still can't duplicate the problem so. :)
I resynced today for the pure purpose of starting from scratch. Everything should be all good :)
The PRL/Profile update mechanism is still acting wonky so I've removed it for now. Next project: custom OTA updates ;)
I /just/ pulled in the signal strength display fixes. So make sure to grab the latest frameworks/base.
ARRRGH! Gotta love starting over. ;)
Drew ota updates would be a godsend for custom roms :)
I have tried installing this quite a few times and every time i get an error saying it cant be installed. i hope maybe the new stable version will update. im so jealous of all of you. i want to get in on the new fun rom....:'(
Call settings??
Gotta agree, OTA updates would be amazing!
Are you having problems flashing the rom? When do you get the error?
It just worked for me that's odd try reflashing or the update he's trying to work on.
I cant seem to find the link for the stable build..... I really want to flash it....
Status
goldalignreview
