ARCHIVED: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2011)
Status
Not open for further replies.
Re: Drew's CyanogenMod Hacking thread (current build: 08/01/2011)
I will just wait for the stable build..... will it be anytime soon???
Ok.... thanx will come back on here later and flash the rom.......
Yeah, especially when rebuilding means a 2-3 hour build time because my processor sucks at compile jobs....
Sent from my LG-LS670 using Tapatalk
lol!! more like this:
Just flashing the new STABLE build now. Will update this post when uploading begins.
I'm having a hell of a time with random reboots. It happens several times a day, when I'm doing different things. Sometimes it will reboot a soon as I start up an app, sometimes when I go to wake the phone it will be turned off and It has to be turned back on. Sometimes it won't turn back on unless I have the charger plugged into it.
This happens at all processor speeds and with different governors.
Amy ideas?
Amy ideas?
Mine is stable on all 4 optimus I have 2 first Gen and 2 2nd Gen phones. It maybe a issue with your phone it self bro I hate to say. Also you might try removing the SD card for a while see if the reboots stop I had that issue once with a bad mini SD.
Amy ideas?
When you flashed did you do a full wipe from recovery first?
Sent from my Optimus S
I have a 1st gen Opti S and my Wifi tether crashes as well. Also, signal strength doesn't go beyond one bar ...?
Yes, full wipe. It very well may be my phone, I don't know. Just for the heck if it I'm going to (with great regret, because I love this rom) flash another rom.
I had that happen to me a month ago, I fixed it by replacing my battery.
If you're running Build ID DREW-003 the wifi tether crash is a known issue. Not sure about your signal strength, but I'm uploading a new STABLE build that has some signal strength fixes so please be sure to flash the new build once I officially release it.
I'm refreshing constantly as we speak! :)
At least it would give you a idea if its a phone problem or not. :cool:
Hey drew quick off subject question, can you point me in the right direction on how to edit ROMs source code? I am not sure if I worded that right but I want to build a ROM that has some of the Reborn features I like combined with CM7 ... One being the "taskbar" has the ability for four apps to be placed, I thought that was a great feature with Reborn and theres some coloring of the icons I'd like to see with CM7 when pressing the Settings button.. (not sure there could be a theme for this?)
You can change the number of apps in the doc bar on the bottom of the phone if that's what your talking about, the default is like 3 but I have mine set to 5 now.
I have 9 apps.
When I swipe up on the ADW lanucher dockbar, it then becomes a scrollable dockbar.(I just learned this last week)
Oh really!? Sorry, I'm new to this .... so how do I change the doc bar?
[INFO]New Stable Build:
The first build in the new STABLE line has been released (Build ID STABLE-001). This build brings in some of the more stable features of the experimental/unstable builds along with new changes in the IHO repository, namely bluetooth fixes and CDMA signal bar display fixes. Hit up the front page of this thread for the details![/INFO]
Reactions: bklyn
Status
Dsignluckmezc
