ARCHIVED: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2011)
Status
Not open for further replies.
I can't seem to get great battery life. I can bet 9 to 11 hours before charger warniy
Sent from my LG-LS670 using Tapatalk
Re: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2
i rooted and flashed cyanogenmod 7 on my lg optimus v and now i cant get the wifi working.:( i also cant acces the activation app on it.( Its a virgin mobile phone ). i havent used my phone 4 about a month now. cant seem to fix the problem. can some1 explain 2 me or help.?
There's a version for your phone: http://forums.androidcentral.com/op...inferior-human-organs-unofficial-cm7-1-a.html
Flashing that should have you back in business. This is a thread for the optimus s. Good luck!
Is there a fix for the rotation lag yet? That is the only issue I have with this rom. I love it otherwise.
The rotation lag is normal among all roms. The lag with CM is the same as all other roms for me. The lag is there purposely so your screen doesn't keep bouncing from horizontal to vertical when you don't want it to.
What app are you using to get the battery charts
Sent from my PC36100 using Tapatalk
Those charts are built-in to Gingerbread, just go to settings - About phone - Battery status, then click the graph on top.
Yeah, I would probably get rid of the battery app as well as "Juice Defender..." and turn off GPS if you're not using it.
Did you re-calibrate your battery stats when you flashed CM7?
Correct me if I'm wrong (please!), but if I do a complete wipe of my memory card (expect for the rom, kernel, battery tweak, and gapps zips) while doing a clean and total reinstall of CM7, the necessary file will be rewritten to the SD card, right? Maybe?
Does mms work? If so how do I get it to work, won't send or receive. Using stable build.
Sent from my SPH-D700 using Tapatalk
Reactions: sryans2004
Bug report #2
Headphones do not transmit call speaker.
When pluging in your headphones the earpiece stays on instead of transfering sound over the headphones, it does show that the headphones are plugged in and no other apps can be running.
Noticed that apps like pandora and music go over headphones fine, just the incoming voice from call goes to default phone earpiece
You mean the update PRL section of that link?
Yes. Post #2, question 2. It's the same steps for the process that you need to do.
BTW, don't do a backup (or restore) of your current system in recovery if you are having issues. You must start fresh. You will need to flash the ROM and gapps over like is listed in the steps.
Okay, Thanks! I still have to go back to a stock rom such as Reborn?
If you want to update the PRL while you're at it you can. Otherwise, just start with the wiping. About 3/4 of the way in after updating the PRL.
I have the latest version of PRL, and I am back on CM7. I still can't send pictures....
EDIT: Doesn't seem I can get data at all. I turned wifi off and I have no data icons showing.. Probably the reason why I am not able to send and receive pictures, any idea on this?
Status
hackerbyron7
