DROID BIONIC Jelly Bean Update
Sam,
Any updates on the search to find a root exploit on JB? Or has that been exhausted to no avail? Hadn't heard anything so thought I would ask.
Thank you.
Sent from my DROID BIONIC using Tapatalk 2
I can tell you right now that log is NOT from a reinstall option. It's from the fix CDT option. So, I don't know what to tell you.
Well I run the HoB and pick option 1) 987222 options then I pick option 2) reinstall 987222 then 2 other screens that tell me about not having safestrap iinstalled and how to turn on ADB when ai continue it goes to this screen.
Flash Mode:RSD
Looking for device [AP fastboot]
7-zip <A> copyright 1999-2010 igor pavlov 2010-11-18
processing archive 987222 blur version 6.7.246.xt875.verizon.en.us<987222>.zip
extracting cdt.bin
everything is ok
size 16384
compressed 337383111
file <s> copied.
check to make sure flash was successful.
Sam,
Thank you.
I haven't heard anything either. Last I knew P3Droid was reaching out to Dan to see if one of the RAZR exploits could be repurposed for the Bionic. I was told it may take a few days. Haven't heard anything since.
Flash Mode:RSD
extracting cdt.bin
everything is ok
size 16384
file <s> copied.
Like I said, it's not doing the right thing. I don't believe it's a bug though as I've had about 3 other people do this. Switch flash modes to moto-fastboot and try again. See what happens. Copy the output from the HoB cmd window when it's done flashing and paste it here.
A BIG thanks to Sam and his HoB! I had problems updating to JB via OTA and I went through HoB and now all went through without a hitch!!
Mad props!!
Flash Mode:fasstboot
extracting cdt.bin
everything is ok
size 16384
sending cdt.bin <16kb>.....okay
writing cdt.bin.......okay
rebooting into bootloader....okay
extracting cdt.bin
everything is ok
size 16384
When you see this menu:
SamuriHL's House of Bionic 10.0
FLASH MODE: RSD
Choose an option:
1) INSTALL 987222
2) REINSTALL 987222
R) Repair AP Fastboot ERROR
M) Main Menu
E) Exit
Please make a selection:
What key are you pressing?
FLASH MODE: RSD
Choose an option:
1) INSTALL 987222
2) REINSTALL 987222
M) Main Menu
E) Exit
I choose 2) REINSTALL 987222
hold on a second I checked tho house of bionic and it only has version 9.5 which is what I have not version 10.0
on top of my cmd screen it says SamuriHL's House of Bionic 9.5
Well, we're waiting a lot of time so I'm going to just have you do some stuff manually as this isn't getting us anywhere. Basically it's not finishing the flashing. I'm not sure if you're not going to the next step after the first flash or if there's something wrong. Either way, let's just get this done.
o) Put your phone in AP Fastboot mode and connect to USB
o) Open a command prompt to the SamuriHL_HouseOfBionic folder then type the following commands:
utils\moto-fastboot flash system 246_FXZ\system.img
utils\moto-fastboot flash preinstall 246_FXZ\preinstall.img
utils\moto-fastboot flash boot 987222\boot.img
If those 3 flash commands succeed, shut the phone off, then boot into recovery and apply the update. Done.
That's because I haven't release version 10.
I understand that I checked the HoB it doesnt have a version 10 am I missing something where is it so I can update.
How do I use this "new and improved" keyboard? I had been using TouchPal Keyboard V5, but wanted to see if the new stock one is any good. If anybody knows how to enable the gesture typing on the stock one, or knows a better keyboard I should install, can you let me know? Thanks!
How do you Open a command prompt to the SamuriHL_HouseOfBionic folder
This is a windows thing. You open a command prompt and cd to the SamuriHL_HouseOfBionic directory on your desktop. Once there, type the commands I gave you.
(You can always hold shift, right click the SamuriHL_HouseOfBionic folder in explorer, and select Open Command Prompt Here)
Samuri Im sorry i must be doing something wrong on the cmd line I open the prompt to house of bionic using the method above then cut and paste the first command it looks like this
C:\users\david\desktop\SamuriHL_HouseOfBionic>utils\moto-fastboot flash system 246_FXZ\system.img
It then says error: cannot load '246_fxz\system.img'
Does that file exist? I assume you have a 246_FXZ directory in there, yes? And it has the FXZ files extracted? This could be part of the original problem if the HoB wasn't installed correctly.
the fxz directory is in there but it is empty I downloaded the fxz again after the first failure and the HoB did it's stuff but it is still empty. Do you think I should unistall the HoB and start all over.
- - - Updated - - -
I lied the FXZ is in the folder
ameliadinkins
