amyf27
- Oct 24, 2015
- 9,907
- 277
- 83
Re: Note 4 or 5?
			That's what I was looking for on tmobile site, but I didn't see any certified used note 5s. Maybe if I had called instead I'd have found one. But at any rate, got a new note 5 on the eip plan, mfg warranty covered-debating on whether to add Jump to it or not. Love the Note 5. Not sure if your bank participates but Samsung Pay was a huge draw for me. I can use it on the N5 anywhere you slide a card-no need to search for tap not pay registers. Note 4 uses android pay which is limited to tap n pay type registers-like apple pay is. Now, note 4 wasn't a bad phone at all-inclusive had that as well in the past, but between the 2 the Note 5 is better overall in my opinion, along with being a year newer - out in 2015, n4 in 2014. N4 does have remove able back and SD slot if you need them, so depending on your needs one or the other may be better for your caseJust got off the phone with T-Mobile and they have a Note 5 certified pre owened for $499 and $0 upfront. But I'm going to think about the Note 4 again. Its easier to pay eip than paying out right for us right now. I never did like the back of the note 4 kinda bulky. My Note 4 seemed to be slowing down the last few months of having it. Maybe if I get it I'll keep it stock and not root. I've out grown rooting. Plus I like the newer features Samsung has and I'm afraid the Note 4 may never get them.
I'm really thinking turning mine in really soon. I used to have the Note 4 before I got the S7E. I seen on eBay they have them as low as the mid $200's. What is the latest software the N4 has? Will they ever update to the Grace UI since the 7 is no more? Also should I go back to the 4 or try the 5? But I'll miss the AOD no matter which one I get. Will the S-pen fit into the N4? Decisions decisions?? Which phone has the better battery life? My Note 4 was lossing battery life before I sold it.
