[HERO ROM] Gumbo ROM project - in Beta
Status
Not open for further replies.
gbhil I love this rom and kernel. The only thing I dislike is the clear notification pull down. Could you or someone post the original?
Like the lock screen, if popular opinion wants the stock look back I'll change it in the next version. So far yours is the only voice that's expressed an opinion, so back to stock will be the plan.
I've said before - I don't even like the restyle of Rosie. The issue is one of performance. The images inside the apk files need to be small in size, decent in quality, and uncompressed pngs. Old Rosie's not coming back. If at all feasible I'll swap back to the stock shade background. I don't see an issue.
me personality i will do a strip down of the rom.The only basic service will be phone,google and all the essential to get the phone functioning and later push the file that you want.For example i have removed all the widgets and programs that i don't care about and kept what its needed slimming it down.
I wish i can figure out to do a custom rom base of yours.lol and strip it down before i install it. :)
I'm considering just that. Completely stripped base with add on packs for Rosie, Sense widgets, and add ons.
And I'm loving what you've done in the screenshots!
I like the clear notification slide myself
LOL way to make it easy for me :)
Add clear widget themes to the mix above.
I have been hearing a lot about the gumbo rom and I thought I would give it a try. I just want to make sure I have read everything correctly. Boot to recover then wipe data then flash the gumbo rom and then later I can flash the beta kernal with the memory enhancement? Is this correct?
Correct, but make sure to backup via Nandroid first.
@spj - once again, very nice. Could I get a full res version of the lockwallpaper please? :)
I flashed this and my internet didn't work is that a known problem?.....other then that great work loved the cube being added...thanks for keeping peep that's the only thing I don't like about fresh 1.1
Nope. I would try wiping dalvik cache from the recovery or wiping and reloading.
Hey gbhil, somewhere I heard that you had a 1.5c version out of your gumbo rom. Is that your latest project?
Status report:
Flashed Gumbo 1.5c yesterday. Haven't had a better battery experience with any other ROM besides this last one. It runs great and my battery percentage right now is 75% or so after slight/moderate usage turning off the Mobile Network/WIFI/GPS when not in use. It has been 16 hours or so since disconnect from wall charger.
I have experienced a slight lag with this last Gumbo 1.5c release compared to other ROMs when using the Gumbo-31-kernel. Also I did experience a OMADM process com.htc.android.omadm is not responding warning.
Right now, its one of the best if not the best ROM I have used.
my cube always force closes when I try to play videos.... they are on mp4 format.. does the cube even play vids?
Status
Lilrose
