[HERO ROM] Gumbo ROM project - in Beta
Status
Not open for further replies.
Testing Kernel and Rom. Will post updates tomorrow.
Update: It seems like I have to go in every time and refresh SetCPU to bring the CPU speed back up. Is that how it's working with other people's?
Yes. Our (heroc) kernel source needs debugged to work 100% with or without setcpu. I've got an idea to fix it in the ROM if the setcpu dev doesn't have any ideas for us. More details in the kernel thread.
Applied your ROM over Fresh 1.0 without wipe after reading the posts and had no problems at all. Love this Rom. Runs smoothe and I applied all my tweaks that I used with my other ROMs with no problems either. I have a request, though, and you seem to be the man to go to. I've seen the Google Live Wallpapers working on the Sprint Hero using ASOP, but I prefer yours or Fresh. Is there any way you could import it? Just wondering. Thanks for all the hard work, gbhil.
Live wallpaper needs libraries built on 2.0 or higher. I've got it to run on 1.6 without force closing, but it didn't do anything, I think we have squeezed all we are going to be able to from 1.5 and now it's time to work the kernel.
So far so good with this kernel. I did have a fc issue with sense of all things. I may wipe and reflash gumbo and put the kernel back on. My battery is so so. I've had issues with it prior anyways.
for the force close issue i found that using these commands can clear cache following by rebooting the phone and everything is smooth afterward...
rm -r /data/boot-cache/
rm /data/dalvik-cache/
good luck
Hey, I just notice I don't have Visual Voicemail on my phone running Gumbo 1.5b and the latest .31 kernel. Is that supposed to be like that?
Awsome Rom
All new release. The ROM has been reworked using MoDaCo's incredible build scripts. This gives great performance while keeping all the features.
Gumbo Kernel BETA release - see post 213
What's included:
Apps2SD (see post below)
Dropbear SSH server (see post below)
Spare Parts
Mount USB quick mount app
Phone Portal (administer your phone over WiFi via browser)
Car Mode
Quick Boot
Wireless Tether
Catharsis Calendar Widget
Voice Search
Latest Version of Maps for 1.5
Samsung's Behold II Cube media app
Rosie has been reworked, runs very fast and uses the new Expresso style interface.
A wipe is suggested before installing, because of the new build scripts. If you choose not to wipe, note that many apps have been placed in the /data/ directory for easy future upgrade. At a minimum all caches must be wiped. Note that prior versions are no longer supported, please update to latest before reporting bugs.
As always, this comes with no guarantee, and I'm not responsible for anything.
Donations - please use the money to buy your father an issue of Popular Mechanics to read on the john instead.
Thanks and credits -
MoDaCo
Cyanogen
Lox
JF
everyone else I may have missed.
Gumbo 1.5b ROM
Download Gumbo_1.5b-signed.zip from Sendspace.com - send big files the easy way
http://biggz.dontexist.com:14725/ROMs/Gumbo_1.5b-signed.zip
Add ons
All removed Stock apps - Apply as an update AFTER flashing the Gumbo_x.x-signed.zip
Gumbo ROM
Individual apps - Apply as an update AFTER flashing the Gumbo_x.x-signed.zip
Gumbo ROM
Please keep the thread on topic. Any questions about how to root or how to apply a ROM should be addressed in the appropriate thread. Lets try to keep this one about issues/suggestions about the ROM.
ALWAYS FEEL FREE TO SUGGEST FEATURES! Don't depend on me to think of everything...I'm getting old and my mind wanders. :D
Is there anyway to put the Cube app in other roms or do you install it like a normal apk file?
Yes. Sprint VVM is not in the ROM. The sprintcore is there, so it's possible pushing the apk to the phone will be all that's needed. If not, I'll investigate.
It has several shared libraries, and would need to be assembled by a ROM cooker or each file individually pushed to the phone. Installing the apk won't work.
Ok, i put together the file needed to run the cube.But before you install this do a nandroid backup first I have not tested this on another rom. I'm not responsible to whatever happens to your phone or support can not be provided by me.
DOWNLOAD
good luck
gbhil,
I just noticed that I can not do "Voice Search through Google Maps" anymore, is there a way to add that back in?
DOWNLOAD
good luck
Perfect. Looks like all the libs are in place and any cucpcake rom for a phone with an onboard gpu should run it just fine.
gbhil,
Yes that's a known issue. Pushing voice search back will not fix it, as some speech libraries are also missing. It will be corrected in the next release.
gbhil,
attached is the speech lib that you need push it through recovery.It worked for me.
Status
mnwstl
