[HERO ROM] Gumbo ROM project - in Beta
Status
Not open for further replies.
I have had a issue since 1.3 and thought it might be a bad app! but after a few test with apps and without any apps added i keep leaking memory. And im not sure if this is a rom issue or a app issue that was added to the rom from the last build?. but if i restart my phone ill end up with a little over 92mb and through the day i only make calls or check the weather or The NFL app Then by the end of the day i might have a 49 mb left!. can you give me a idea to what it might be and if any other people with this problem. thanks
Also one more thing. is it possible that i didn't fully root my phone but it took some of the root? cause i have yet get the APPS2SD to work? I have done everything i could a clean wipe and just partitioned my sd cart and all that stuff.. So i just wanted to know if that was possible? Thank G
Sprint HTC Hero. Running Gumbo 1.3 custom rom.
Update - it's not just you. It's not working for me here either. Trying to determine why, but real life has been in my way :)
Memory - where are you getting these memory readings? I need to know if it's app memory, system memory, etc. I haven't seen any issues like this so I need to know where to look.
Apps2Sd - shell into your phone and give me the output of these commands please -
Code:
adb shell
cd data/app
pwd
will return one line.
Code:
su
whoami
Code:
ls /data/
will return a list of files and directories
Code:
ls /data/app/
will retunr a list of installed apks
thanks.
hey i figured it out ... i have a leak in the reboot app i forgot to take that out.. im gona start from scratch with my phone and go back to stock rom and reroot. thanks
Good to know it's not just me (I suppose). Did you move the default location for the wallpapers? I thought it was supposed to be at /system/customize/resource, but the images there are not the default wallpapers on the phone.
The reason I ask is I'd like to symlink /sdcard/AndroLibWallpapers -> /(wallpaper folder)/ so when i download a new wallpaper it will show up in the wallpaper library.
I didn't move the default walls. I don't think that's possible without another app (metamorph style app that can inject files into an apk).
HTC walls are stored in /system/app/Rosie.apk in the /res/drawable480x320 folder inside the apk.
Android vanilla are stored in /system/app/Launcher.apk in the /res/drawable folder inside the apk.
New version up, full of surprises.
See first post
Awesome!! Dying to try this. I cant download it for some reason from 4shared, when I click the download now link, it just goes into a loading loop. Hopefully it will get sorted, and I can use this ROM! Looks awesome.
Seems to be a problem with the MediaFire mirror. All it does is recycle the page over and over...RS seems to work, but slow.
I've downloaded, wiped, and when I try to install I get -
Install from Sd card...
finding update package...
opening update package...
verifying update package...
E:No Signature (777 files)
E:Verification failed
Installation Aborted
same problem here :eek:
Having internet issues ATM I think. File sizes don't match.
Will update when i get it sorted (I hope lol)
Status
Andacar
