[HERO ROM] Gumbo ROM project - in Beta
Status
Not open for further replies.
gbhil, just thought Id let u know I just flashed your ROM from Fresh 1.1 WITHOUT wiping and everything is working PERFECT so far!! Great work!!! Still testing all my apps but so far so good!!! Thanks for a great rom!!!
Nice to know. Thanks for posting, and I'm glad you're liking it.
I tried out the SMS count and it kept force closing whenever I rebooted my phone. LOL Needless to say I uninstalled it.
When active, anytime you answer a call it's goes to speakerphone by default.
Does that here too. Stop rebooting your phone lol.
LOL I had too. I was trying to figure out the lock screen stuff. On a previous ROM I had the clear lock with no background. How would I get that back? On Edit, this ROM kicks ASS!! Good work!
pull /system/framework/com.htc.resources.apk
inside look for /res/drawable-land-480x320. There's 4 png files. The lockscreen_prompt_back.png is the shading that appears when you get a notification, and the other three are the arc.
Make them transparent, copy them back to the apk and push it back to the phone.
delete everything in the /system/etc/lockscreen/port folder
delete /system/HtcLockScreen.apk
reboot.
reboot.
Thanks dude! Im gonna try that tonight when I get home.
My last post was made with my left pinky while I was eating lunch at Jack in the Box. Short and sweet :P
What I want to say about this ROM, though, is that it is QUICK. Question: Where do I go to edit transitions? The zoom in and out is nice, but I like the sliding side to side that is stock on the Hero. Is this something I can change myself without being an expert ROM cooker?
Good luck!
lol. I haven't had crap in the box for ages. Not much of a fast food selection here in the woods :)
Look in /system/framework/framework-res.apk
Inside you want to overwrite the files in the /res/anim/ folder with the files from a stock Hero ROM.
I'll check it out. Does mms work in this ROM? My wife has been sending them to me today and I haven't been getting them. Wondering if its a Chomp issue or with the ROM.
woww i AM NOT GETTING MINES TODAY EITHER!! Im JUST about to do a RUU flash!! All mine does is it comes but it stays on downloading and doesnt open hjow aboutou
Just checked with a pic, a slideshow and a small video. All worked here. Do you guys have wifi on maybe?
reboot.
"delete /system/HtcLockScreen.apk" Can not be found...I did the others and it made no difference.
reboot.
Nevermind, found it.
I don't believe Chomp supports MMS. I know Handcent does.
WiFi was on for one and off for the other.
@ esoteric1311 ChompSMS says it supports MMS. The system permissions support it and so do the app settings. In the stock messaging app I have auto-retrieval turned off, but it is turned on in Chomp. Does that make any difference?
**update**
The messages are coming in. A bubble pops up and says "new message" briefly, but then it goes away without retrieving the picture. Weird. I'm using all default settings except the notification tone and vibration, T-Mobile network, and "Show only mobile Contacts."
**update**
use handcent sms it's alot better then chomp.I have no issues sending or receiving sms and mms
Status
DannaOgle83
