[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
When it says that it will wipe data? What type of data?
How can I backup my information? Is there a particular program? Thanks for the advice fellas.
Ok guys. it worked. excellent job. How do i access my backup files from titanium backup? Do i need to re-root my phone first?
no if this worked at all then you are already rooted
turn on unknown sources
settings>applications>unknown sources
turn on debugging mode
settings>applications>development>debugging
download and open titanium
hit the backup restore button at the top>hit the phones menu key>batch>restore missing apps + Data,,,, not system data
or you can just go to backup and restore and just select the particular apps you want to restore
Went for it.
Another fascinate on 2.2 here ! Thanks to everyone working on this.
It actually went too easy, there has to be a catch somewhere. LoL
Lol , congrats...love the name btw , it has what plants need
Went for it.
Sent from my SCH-I400 using Tapatalk
Can someone give a list of all the new features that the Froyo offers? I saw a new gmail and market.. anything else?
Anybody have trouble pairing with bluetooth headsets or car bluetooth handsfree on superclean 2.4?
sent from my rooted NookColor
I don't know what I am doing wrong. I plug it in to the computer just as described above. The phone resets, but when I run titanium backup...it's still showing I have not rooted the phone. PLEASE HELP!
I am confused at where you are in the process, please give us more details.... and welcome to android central
Thanks for the quick reply!! I have to get this done before bed for my dad. I rooted my fascinate like around christmas with the one click root and it worked flawlessly but it would not work on this. So I found this website. I downloaded update.zip and put it on my phone files. I downloaded super clean version 2.1 and extracted the files. I downloaded ODIN. Then I did these steps:
I unpluged my phone and removed battery. I launched ODIN and then plugged the usb cable into my phone and held down the volume-down key. I then plugged the fascinate to my pc and when the yellow triangle came up I released the volume-down.
I clicked on PDA and chose EB01_DXC.tar.md5. It said FAIL!!!!!
So I restarted and tried it again. After 15 mins. It powered down. When I turned the phone on...NOTHING
What am I doing wrong?
Ok...I tried it again and now I am on a system recover screen and I have the options:
reboot system now
apply sdcard:update.zip
wipe data/factory reset
wipe cashe partition
I'm not touching it until you tell me what to do.
First update your drivers HERE
Next disable any antivirus
Use USB ports in the back of the computer , if you already are change to a different port
EB01_DXC.tar.md5 is stock froyo not Superclean ...try 2.4 instead
try those steps and let me know if you have any luck
bassey
