newboyx
- Aug 3, 2010
- 1,037
- 144
- 0
I am, I thought that bug had been fixed. As always, its the obvious solution. Thanks
Glad to help.
Scott, today I installed CleanROM 2.8 on my hboot 1.5 phone. I used the HTC method, then your TWRP script tool (thanks!), then flashed the ROM, then used fastboot bootloader to load the boot.img I pulled from the CleanROM Zip file. I believe I did everything correctly.
The phone boots properly, I can do stuff on the phone like using the Market, web browsing, weather app, etc. However, my 3G speeds are atrocious. Not bad, but absolutely atrocious. What have I done wrong?
Be gentle, if you don't mind. This is the first time I have ever done any Android rooting/flashing/customizing. And thank you for making such a nice ROM. It really is fast.
Maybe do a profile and prl update (in that order)? Just my .02!
Sent from my PG86100 using Tapatalk
Reflash the rom, but only clear the caches. Don't do a full wipe.Quick question. I want to remove beats and use crt animation instead. I understand I can't use them both together on 1.50. How do go about removing Beats? It's not in the app list. I got beats from the rom updater.
thanks
I followed your advice and it did help a lot. My speeds still aren't all that great, but it's far, far better than it was at first. Honestly, I think it might be the 3G tower near my home. When I went out to lunch I performed the PRL update and Profile update. After I did that I ran the speed test again and got great results (over 1Mbps). Then I came home and ran the speed test again and it was pretty lousy, but still better than what I had at first.
Thank you for the tip.
Scott, and other kernel gurus, would you take a look at my Hboot 1.5 guide for newbies and see if I missed anything? I don't know for sure that I did the kernel installation properly for a new installation of CleanROM 2.8 onto an Hboot 1.5 phone. Thanks everyone.
http://forums.androidcentral.com/ht...-5-unlock-install-twrp-recovery-cleanrom.html
You are on HBOOT 1.5, search this forum for information on flashing the kernel so that you can use WiFi and 4g.I am getting that problem with both wifi and 3g connections. Also Rom updater crashes on me, what is the fix for that?
