[ROM][ACS][STOCK] "Swiss Cheese Samsprint" EE03 :: GPS/GTalk voice/video fix! :: 5/16
"Open Odin, load the PIT in PIT and the modem in PDA (or Phone - both work). Uncheck everything on the left except Auto Reboot. Click the big button."
where is the PIT file at?
Its a taste of how GB will run on our Epics, some might use it as a daily driver, some will just try it for a bit and go back. Me personally? Im waiting for EXT4 support, which more than likely will be when the official drops.
Incorrect. As long as you are on CWM3025 as per instructions, this ROM will automatically convert you to RFS.
Sorry if this seems obvious, but if I have SRF already installed (flashed with CWM 3.0.0.6), can I simply flash CWM to 3025 and then flash the GB ROM?
Noticed the lag too, but thought I had gotten used to EXT4 speed - nice to know I wasn't imagining it.
Quick quadrant showed back to 976 , pretty much the same as Froyo .
Got GPS online after re re reflashing back to EC05 and back forward again as the fix didn't work for me - like the feedback said. gTalk fires right up and engages - anybody figure out how to switch to FF Cam ? ** update - > redownloaded and reflashed acs-ee03-fmrgtv - getting call to intiate, but its not right. FM radio will open but the radio will not start.
Noticed the lag too, but thought I had gotten used to EXT4 speed - nice to know I was imagining it.
Probably need another update or a hacked-together version of Talk to get the camera situation sorted out.
Anyone having trouble getting voicemail?
Google Voice is working fine for me. Or do you mean Sprint VM?
Sprint VM. I'm having to dial out to get my messages. Press 4 to keep, press 7 to delete...Like old times :)
I've also noticed that I couldn't pick up or make phone calls. Probably just a bad flash and will have to reflash :P
Yep probably a bad flash. Only problem I've had is FM radio doesn't work but that is simply an additional goodie so it doesn't bother me.
My baseband version ends with EC05. What did I do wrong? Does that mean I'm still on EC05 modem?
Odin is the only major thing I haven't tried yet. Rooting, ROM's, flashing this and that I'm getting decent at, but Odin kind of scares me.
