[ROM] Android Open Kang Project- Jelly Bean Style
Francos kernel runs way better then that crap that comes with the ROM.
Sent from my galaxy nexus running jelly bean!
There was a new nightly released. Anyone flashing from Build 1 to it?
Sent from my Galaxy Nexus
Changelog according to Jubakuba from RW (more maybe added later):
[Updated to 8/24/12 : CHANGELOG FROM Build 1]
-Exit to Home on End Call
-ADB over WIFI (Settings>Developer Options)
-New Wallpapers
I flashed it and maybe it's just placebo but I think it feels a little smoother.
Sent from my Francoed Unicorn
2100 mah battery. Wifi majority of the day. All 3G and about an hour of podcasts. Using LeanKernel 4.2.0 exp3 180
Sent from my Island using my Smoke Monster
OK to DF this jump? or I just might wait a few more releases if DFing is OK.
I have noticed that is is sluggish compared to Euro10, not sure if its the kernel or the ROM. Might have to try Franco out. also I it has been freezing, if I try to use the back arrow to backout of an app it will hang take about 30 sec's before it happens.
Change that kernel post haste!
Reactions: Xanth269
The Milestone actually came after the latest nightly (r241), so I'd say go with that.
In regards to flashing kernels, can you flash them in the same session as the Rom (with original kernel) and GAPPS? Or should you boot up first then reboot back into recovery to flash the new kernel?
In most instances you can get away with that, but I really recommend doing it in a separate session. Minimizes risk, ya know?
Reactions: Canuckfan
Is it problematic to let Franco's app flash it or is it kind of like flashing ROMS through ROM Manager?
Nah, I trust franco and have NEVER had a problem auto-flashing. The current setup is much better than the prior one though; at least with this one you have an option to restart instead of it auto rebooting.
Reactions: cyberdalek
Flashed Franco with his app, seems to be much smoother.
Aokp and franco = heaven
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
Can anyone get calendar events to show up on the lockscreen? When I click on calendar sources, nothing happens. I love this feature on skank.
Olivianoah43
