[ROM] Android Open Kang Project- Jelly Bean Style
A couple of things I'm wondering if possible. If you have a locked screen, can you set the emergency number to call someone you know? To let them know someone found your phone?
Sent from my wireless telephonic device.
How old is the build you'reon?
4.1.2 based? Probably safe.
Otherwise...I wouldn't.
Dirty seems fine. I did come from a Dizzy Thermal 4.1.2 build though. Thanks for another great build Jubakuba!
No problemo.
Forgot one of the cherries I picked...
More longpress targets in keyboard.
(Rows 3/4 now have long-press keys)
Had some users on Rootz crying about the lockscreen before secure unlock being missing...
So I made them a present...
That being said, the present (I don't think this is my fault) doesn't seem to work completely...in that it doesn't open any targets.
It'll just show the unlock ring, then your secure lock. And no matter what you select it simply unlocks.
The commit is ancient...I think it needs to be completely rewritten at this point.
Other than that...build is solid from what I can tell.
So if you don't mind a completely new feature not working as intended, flash away.
I'm a liar. Works fine!
_______________________________________________________________
All this is included in this build:
Merged Gerrit
Along with:
Landscape Lockscreen Target Fix
More Long-Press Targets on Keyboard
Quick Reply Pop-up
Lockscreen Vibrate
Torch Toggle Fix
Ram Bar in Recents Menu
Show Lockscreen Before Secure Unlock
Y'all better love this ****.
Took me ages to rebase correctly.
And I don't even use a secure lock <_<.
That being said; there was a lot of actual code that needed rebasing. I'm not a developer.
Who knows what I did in there =]
I HIGHLY recommend you backup your current set-up.
I HIGHLY recommend you wipe before flashing.
Download:
TORO ONLY
Booyah! I've really been digging the 4.1.2 rom you posted last week but I'm itching to flash. Thanks mate.
Figured this was a fun idea...
If you have Tasker and the ROM I posted (you need the lockscreen before secure lock feature):
Make a new Task.
Add Display>Keyguard with a value of "off."
Add Phone>Call>Input Number Here
Add Display>Keyguard with a value of "on."
Add Display>System Lock
Then set a lockscreen shortcut for this task with RomControl.
Change the icon to something obvious, obviously. If you can find an I.C.E. icon or similar...that way people know what it is.
This task is enough to bypass the secure lock, dial the number, and re-lock instantaneously.
I'll try this weekend. I don't flash on work nights anymore.
Still no vibrate for notifications? Any apps available for this?
Surely you've heard of Light flow. Still works well and I like that you can backup your settings for crackflashing
C'mon man, I teed you up for something like "No, I've never heard of Light Flow and don't call me Surely" :p
You can see for yourself...
gerrit.sudoservers.com/#/q/status:merged,n,z
Lockscreen targets...
NavBarWidgets...
Whole slew of stuff.
THat's all Chinese to me..I could never get that gerrit stuff down, I need to see the real deal in my hands in FULL DISPLAY to really enjoy what's available. (Thanks for the link I'll take a look)
So is build 5 for sure coming today? I tried looking on Twitter and Facebook but didn't see anything to indicate that that was the plan, unless I missed something.
Thoitrangyozu
