Look here: http://forum.androidcentral.com/lg-...aosp-2-3-3-cm7-gingerbread-24.html#post915774 for the answer to getting the correct carrier to display. Be sure to thank the op for posting the info and not me.Also, would you mind explaining how you were able to get your mms working. Even with gosms mine are still not working. Other than that, I love this rom.
mms... mms... mms... c'mon mms...
Sorry MMS does not work, I cant receive but I can send.
Sms/Text works, Camera Works and Alarm no longer fc's. New options in Cyanogenmod settings.
my mms, sms, and camera all work now, but i use GoSMS Pro its free and it has a setting to be your default mms app in the settings if stock sms is uninstalled which has saved me, NOW, my camera does not work when i set it to auto zoom and things like that i have to turn off auto focus, macro focus, and those things, but i still love this freaking rom!
Are you sure your MMS is working? The issue is with receiving MMS. Try to send yourself an MMS. You should receive it. Let us know what happens....
it works with gosms pro MMS WORK
ok, so im on the latest version of aospcmod-ov, with the flash to sprint from that forum, with your new .zip info [blue pill], i use GoSMS pro with the "i dont have a stock sms application" checked off, and i sent myslef a picture and i recieved it, and i sent one to my friend and he got it.
sounds promising... definitely going to try this out tonight. anyone else want to confirm?
Says MMS is working now, so there u guys go, sorry i couldnt help u with my fix before
LG Optimus V What Works - ROMRepo
It's always worked for the Optimus V, which is what that site is referencing...
EDIT: If you somehow think of the steps please enlighten us. We will be very grateful!
well what i explained was pretty much straight forward and works for me :/
1.Go to market download GoSMS
2.Open GoSMS and press the menu button on your phone
3.Go to settings
4.Go to Important Tips
5.Scroll down to where it says "Stock SMS uninstalled?" and check the box
6.Restart your phone just to be sure it makes it handle it
7.Try to send a MMS
3.Go to settings
7.Try to send a MMS
yes i send and recieve, my mms works perfect for me
