[ROM] CM-10.2 4.3 rom + 3.0x kernel
I had to install a couple times to get everything working correctly, but here is the order I used:
1. Wipe & flash rom (build3)
2. Flash VirginFix
3. Reboot
4. Flash Light Gapps
5. Reboot
6. Manually install FIXED-int2ext+ by placing 40int2ext into init.d folder
7. Reboot
8. Install third party keyboard (Swiftkey for me)
I don't know if this will work for you guys, but it's what worked for me.
What int-ext script do you use? I haven't found one that works yet.
Also, did you use gapps that he didn't link to? The link in the OP gives me a 500 error.
Ohhh I tried flashing build 2 .. could build 3 have been a fix to some issues ?
I also missed the build 3 and have just been poking around build 2. Can't wait for the dl to finish! :D
Update: well now I've got it up and running on build 3 and for once I can actually download apps. Lots of Google services fcing though
Tapatalk'n it Squid style on JBC 4.2.2 from my VM-670
Even though I don't have an sd card, I'm going to try and put it one my system partition. Anyone think this will or won't work?
Previous Username: UnrootedDroidOwner
Current Phone: Lg MACH(LS860)
Old phone: Lg Optimus S(LS670) Currently my MC:PE server hoster:)
And soon to come is a Nexus 7 2012:)
You'll be able to use the rom, but won't have room for much of anything else
I've got about 10mb free on my system partition after rom+gapps+virgin fix using build 3
Tapatalk'n it PAC-Rom style! Android 4.2.2 on my VM670 running LS670ZVJ firmware
Oh by the way, earthnfire78's rngd tool works to get entropy up on this rom and doesn't use much system space
Tapatalk'n it from my VM670 running CM 10.2 Android 4.3.1 by TheKraven
Hmm... Does the screen rotate for anyone else? For me it doesn't
Tapatalk'n it from Android 4.3.1 CM 10.2 by TheKraven on my VM670 running LS670ZVJ firmware
It did for me. In fact, I wasn't prepared for how well it worked, so I keep it rotation locked now.
Hope Goo.im gets their servers synced sometime in the near future. Going bonkers waiting to be able to download. The "download failed" message is getting old, lol
Sent from my ZombieBean 4.2.2-VM670 using Xparent Holo Tapatalk 2
I'll be testing this for a few days, but I don't have service right now so I won't be able to test certain things...
Actually, the battery life is pretty superb so far. I'd forgotten that flashing the stuff and switching between a couple nandroids is battery consuming, though.
Anyway, for customizability, I used the following Xposed tweaks:
XuiMod - Battery bar; animations
XBlastTools - Center Clock and other tweaks
GravityBox - It has everything else, including the kitchen sink.
If you don't know what the Xposed framework is, check out this thread over on XDA.
Also, I've noticed that when uplugging the device, it does do the notification sound/vibrate for charging (I love that feature), but the status bar battery icon continues to show that it is charging for another 30 seconds to 2 minutes.
I can't seem to get any of the Xposed Framework modules to work on this ROM. So far, that's the only downfall. Still testing, but have noticed good battery life. Fast and smooth also. So far, it's a keeper :D Just hoping to get Xposed to work, as I prefer the center clock and custom carrier name features.
Sent from my ZombieBean 4.3-VM670 using Xparent Holo Tapatalk 2
Weird; they work for me. Did you flash/install anything else?
Does anyone else get a "Unfortunately, Setup Wizard has stopped." after installing the ROM?
I can't exit the setup wizard either. I'm on an OV.
There should be a key switch patch somewhere in the s forums.... Use the search tool:D
Install rom, boot, setul. Then reboot to recovery and flash gapps. I found an UltraSlim version with just play store and needed services.
Do you mean set up ? And light or mini GApps ?
Yeah. Most likely. Probably just a typo.
Yeah, meant set up. I didn't use either. I found an UltraSlim version on Xda that i used. Also flashed the FIXED int2ext+ posted a few posts back, and it works really well.
benjifred645
