[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM] CM7.2 Port for Optimus S by thekraven 2/7/2012 zvd only
PLEASE HIT THE THANKS BUTTON IF YOU DOWNLOADED AND IT WORKED FOR YOU..
Hello guys and gals of AndroidCentral...
I have been looking around and I see that most ROMs require you to wipe system, boot, cache, and sometimes data before you can flash a zip file..
I also see that (with the power of Android Edify) you can create a zip that does it for you.
So, do you have a ROM that you want to flash but need to wipe everything and may want to pertain your data? I can help!
I have created a TOOL (well actually two of them).. one wipes EVERYTHING (Boot Animation, System, Data, Cache, and Dalvik Cache, AND /sdcard/.androidsecure)... and the other does the same thing except doesn't remove User Data..
HOW TO WIPE THE SYSTEM/DATA (DEPENDING ON WHICH YOU ARE USING)/CACHE/BOOTANIMATION/"/sdcard/.androidsecure" WITH THE ZIP FILES:
Just Flash these in recovery... NO Need to wipe cache or anything... just flash.. This will remove System Files from your system allowing you to flash a ROM without having to manually wipe the system.
DOWNLOADS
Without Data Wipe - OCDW_without_data_wipe.zip
WITH Data Wipe - OCDW_clean_wiper.zip
How would I go about changing this setting?
Don't bother, I just tried changing it on CM7 and unfortunately it had no effect on battery life with BT on.
So I tried searching the thread, hopefully I haven't repeated someone else's question.
Is usb host mode enabled in this kernel? I'd like to be able to hook up my Garmin (self-powered) device to read / write files from / to the phone.
I understand that the device is probably not beefy enough to power a mouse or keyboard.
Currently, USB host mod it not enabled.
It requires another module to be built, which makes the kernel & ROM larger and takes longer for the phone to boot.
I have no plans to add it, but your welcomed to do it yourself.
Bob
Reactions: alexandergolden
Thanks Bob, I'm a big fan of your work.
I'm an admitted noob when it comes to this. Now to find and execute instructions on how to do that :)
Great ROM thekraven the best IMO
To report some issues I've had with a clean install of 7.1.01 and the recommended ad ons
Ringer (out of speakerphone) and mic doesn't working with headphones in.
Syncing, at least with Gmail doesn't work.
There is a voicemail notification that rings on boot unless you turn it off in the settings.
And the Built in Tether isn't working, for me at least.
I apologize if these are already reported, know issue's or fixed in 7.2. Thanks for all your work.
So has anyone ditched CM7 for CM9? I am on LeWa 2.3.7 until Camera gets a more stable(er??) build of drivers..
Working on it, but my CM7.39A nand will stay on the SD for a long time.
WiFi Is Acting Very Strange. Yesterday I Connected To It & It Worked. But Now Today It Just Says "Obtaining Ip Address" & Then Disconnects.
NeverMind. Wrong Password....
do i need to return to stock to reactivate the phone?
i'll keep searching nobody has to be a dick
sprint guy told me to use sprint lover's rom but cant get it FBI is awesome
This rooted gingerbreak stock VD should work.
http://forums.androidcentral.com/lg-optimus-s-rooting-roms-hacks/86749-gingerbreaked-stock-vd.html
The DL link is broken in that thread, here is an alternative.
http://dl.dropbox.com/u/7078144/stockVD.zip
i used thunderom got the phone making calls. but no 3g service. data is enabled in everyway i know. is this sprints problem?
First off, what does this have to do with cm7 or this rom. Second, thunderRom is WAY outdated and no longer supported. I would make sure you know your baseband (currently supported basebands are zvd and zvh), then choose a rom for it that is still supported.
While in that sprint rom, you need to update profiles and update prl. Make sure thunderrom is for zvd. I remember it was for zvc. But I could be wrong. If data doesn't work still,you need your msl,then dial ##72786##, this will get data and GPS.
Edit..meant msl
i had to use thunderom to activate the phone. i gave it to my girl and i have been running cm7 since last summer and it wouldn't activate with cm7. now i flashed it back to cm7 and i have no 3g
updating the prl seemed to work. just flashed back to cm7 fingers crossed
After flashing the latest build, I lost my visable voicemail and MMS apears to not be working. Sprint keeps sending me messages asking if I bought a new device that doesn't allow MMS messages. Any sugestions?
OP first post.
Hotfixes
7. Sprint Visual voice mail.
Here is the link.
VVMCM7fix.zip
Thanks. Do I just flash that .zip?
In recovery, yes.
If gapps get funky (I don't think they do, but I have been flashing so many different things lately.......... :confused:)
If gapps get funky, flash them and then the vvmfix, then boot.
kenworthysonpartor
