[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM] CM7.2 Port for Optimus S by thekraven 2/7/2012 zvd only
If you are currently on CM7 with data, phone, and gps working, you are on ZVD. To verify what baseband you are on, you can flash or restore a zvd sprint rom to check. It's not built into cm7.
Re: [ROM] CM7.2 Port for Optimus S by thekraven 3/9/2012 zvd only
I want to install this new build but my baseland version says unknown...I'm on a Sprint LG Optimus S(LS670) using android 2.3.7 using CM7.2 with kernel version 2.6.32.9 v3.3...can some one help me or if there is another way to find the baseland version I am using...thank u
cm7 always says unknown, if you have siganl and can make calls then you are no doubt on zvd.
Reactions: sydewayz soundz
If you are running cm7 and have a data connection now, then you're on zvd baseband already. Just follow posted flashing instructions:)
lol 3 answers in 3 minutes... jeeze we must be a bored lot!
lol you guys are on top of it no doubt...thanks a million...I'm gonna download and flash now..
Ok 1 more quick question...what is the difference between the bare bones version and the full version and which one do you recommend?
I always use barebones versions. Smaller and snappier to me, plenty off free app space.
The Barebones has no wallpapers, minimal ringtones, no FM, smaller English only keyboard, removed bootanimation, removed language files (kept English and Spanish).
I also always use the barebones version, space is a luxury on this little phone we all love.
The number of apps and things like live wallpapers. All Android OS components are the same.
from LG-LS670 w thekraven CM9/ICS & Tapatalk
I'm a newbie here so pardon my potential ingorance, but I'm having a GPS issue. I first updated to the 1/16 build after I couldn't take the botched gingerbread update; I had been running it for a while and loved the speed, stability, etc. Then I tried to run a GPS dependent app and realized my GPS wasn't working. I flashed three GPS fixes and still couldn't get a signal. Then I flashed the 3/7 update: no signal. Formatted everything and flashed again: no signal. Three more fixes, re-flash, three more fixes: no-signal.
I don't want to go back to stock ROM but I would like my GPS to work. Everything else works great. Any ideas? I'm out of them.
My GPS works fine in both thekraven builds, this CM7 and his alpha CM9. I would suggest you flash a Sprint based ROM like reborn or the gingerbreaked stock (I posted a link earlier in this thread), try it and make sure your GPS functions there.
Then to a full wipe / factory reset. format boot, system, data, cache, flash the Debug-formatALL.zip in the first post, then do a clean install of the 3/7d CM7, and recommended GApps. Of course use Titanium Backup and SMS Backup and Restore first. After install, you can use both programs to restore USER apps, but never restore SYSTEM data.
Good luck.
I tried to do that the other day and it wouldn't update my PRL.
Ya, I found that I had to do a hard reset (##786#) with my MSL to get my PRL to update, while in Reborn Rom.
My PRL is stuck at 1115 and has been for a while now.
i have 2 things that may not be rom related, the first i will record video and there is no sound, it is just mute. but i can reboot the phone and it will record with sound. after an unknow ammount of time it will eventually do the same thing again.
the second thing is i cant share video through messaging, i have it set to mms quality and tried with a 1 sec video yet it always says sorry cannot add your video to this message.
the sound thing has been happening for at least 4 or 5 months only on cm7, the mms thing not sure because i never tried to share a video till now.
akutama1
