[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM][WIP] CM7 Port for Optimus S by thekraven 9-27-2011
it's all packaged together in the 9/27 rom zip. Make a nandroid backup, just in case. Then remember to wipe cache and dalvik cache before flashing the rom. Then flash the google Apps zip and reboot.
If there are any problems, then try a full wipe in recovery.
Worked perfectly. Thanks for clarifying. I like the new boot up animation!
to make an updated from an older verison, do we have to clear everything?
If your old one is mine, you could just do a cache/dalvik cache wipe. Then flash the rom and google Apps.
Coming from Drew's build, you can try that, but not recommended. Some of his system files may not get overwritten and cause problems. Backup your apps with Titanium Backup and do a nandroid backup before making changes.
If you get any force closures or problems, it is recommended to atleast do a data, cache, system, and boot format from the recovery. Or run the debug system flash zip prior to flashing the rom zip.
09/27 build is running great here.
For some reason, the center-clock 9/27 status bar patch doesn't work for me.
Not a big deal as I just wanted to try it out.
Running the full IHO build - very awesome.
Also - running overclocked @ 825 stable using SmartAssV2 and SetCPU profiles.
Glad I did NOT update to ZVH. :D
Didn't work as in not your taste?
Sometimes you have to apply the center clock patch twice before it works. Like flash center clock> reboot > flash undo> reboot > flash center clock. Then it should stick.
Didn't work as in the clock was still on the right, not centered.
Tried flashing it a couple times - not a biggie - just wanted to try it.
I've got a clock/weather widget anyway so usually ignore the status bar.
Re: [ROM][WIP] CM7 Port for Optimus S by thekraven 9-29-2011
Not sure what release this changed in, imagine its something with the new kernel, but the screen rotation only changes in 90 degree increments. its used to do 180. if you hold it one way then flip it around 180, say to use the camera, i makes 2 rotations instead of just flipping around 180. and i only bring it up cause thats the only change ive noticed that affects my use....effects my use...whatever yall get it.
See if 180 degrees is checked in Settings>cyanogenmod settings>display
Definitely liking this ROM. Went almost 13 hours with light use and my battery was only at 88%.
Love the new stock lock screen, and so far it seems my battery is kicking some butt. gimme a hell, gimme a yeah! thanks broseph, thekraven is the man! woop woop
Tried installing this, the 9/29, and I got this failed error:
Verifying update package...
E:Wrong digest:
system/build.prop
E:signature verification failed
Installation Aborted.
Going back to 9/27 until I figure it out or get a response to what is wrong..
Which version the full or barebones? I'll check it out. Oops, i see now. I'll get that fixed. Thanks for catching that. Both are uploading now, I'll post it when i wake up.
Forgot something simple, eh? No big deal, I'll try it when I get home.
Sent from my LG-LS670 using Tapatalk
yeah got bitten by one zero. THe downloads should be good now.
Zefie didn't add OTA updates, I did :p
@thekraven: Shoot me a PM and I'll show you how "OTA" updates work. It's pretty simple once you've done it once or twice.
Ha, sorry about that drew, I was thinking you but I wrote zefie. Not sure why, it was probably because I was looking at his recovery :D
Will you be updating to 2.3.6 or 2.3.7 anytime soon? The IHO boys have 2.3.7 running now.
Nothing really new but labels and CM7.1.0 is official now.
Reactions: pergerson6
angelag5098
