[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
Tried with cwm and another sd card, didnt work, is there any way to fix the pins??
Sent from my LG-p505 using Android Central Forums
Depends on what happened.
If the pins are almost in the phone you can push them up with a needle or a little screwdriver.
But it's always possible there is a problem with the board.
Already tried with the pins so it must be the board, could it be that the little piece with the pins is loose and needs some adjustment?
They should perform the same.
Can you try to get a logcat from it?
I know there are different versions of the Thrive.
Try to flash the latest weekly, it should be up by now.
Sure I don't mind getting a logcat for ya ;)
But how do you do that? :P
And I'll try the latest P505 weekly, I'm still on the 6/15 P500 ROM :P
I wanted to let everyone know my battery is performing amazingly. All this flashing back to ics and stock made it drain so quick but I used this app on the playstore called battery calibration and right now im at 65% after 1d and 14hrs of just normal use
Reactions: wicabo
I am having problems finding a change long on your LG p505 ROMs, any help? :)
Sent from my Transformer Prime TF201 using Android Central Forums
Agh, why Google? Why does Android SRC only work on Linux?......
Gonna have to make yet ANOTHER Virtual Machine....
Maxyguy666
